SOURCE: only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
SOURCE: GE profile performance electric cook
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
SOURCE: Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
SOURCE: G.E Profile gas cook top #JGP640 ignitor.
I just moved into a house, have a G.E Profile gas cook top #JGP640, the problem is when I turn of the front right burner, the electronic ignitor doesn't turn off and make the other three sparking the same time and won't stop, driving me nut. I double check all ignitors are cleaned. What else should I check or should I just give up????
Here
is a tip that I wrote to give details about why your cooktop will not
spark to light the burners..
Cooktop
Range Stove spark ignition does not work
heatman101
