Good Afternoon Jesslyn, I am happy to assist you!
I understand your washer is not working and flashing LOC; however, I see that your question is listed under Frigidaire FEX831CS (Top Load Stacked Washer/Dryer). This specific laundry center does not have a digital display. May I please have your model number? You can typically locate the serial tag, on the upper front as you open the door.
In the meantime, if you have a front load washer, I suggest pressing OPTIONS and SELECT at the same time and hold for approximately 15 seconds until "LOC" is no longer displayed. I hope this helps!
Thank you - Z.
SOURCE: error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Replace Lid Door Lock Switch , Part # 134101800
