20 Most Recent
Kenmore 3.5 cu. ft. Front Load Electric Washer Questions & Answers
Kenmore Super Capacity 3.5 error code E59
see the error code E59= E59 equals no tachometer signal for 3 seconds.This means that the motor is not signaling to the washer normally and
may be caused by a variety of failures within the motor, basket or the
control board. Generally speaking, the E59 error requires the service of
a Frigidaire professional for resolution due to the technical nature of
the ERROR.God bless you
Washer washes, drains, won't spin but after
Plug off the mains. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean. Check out your pump too, comes after the filter; there could be anything clogging the impeller.
Check motor brushes, if less than one centimetre long, replace.
417-48112701 won't spin
If there is still water in the tub, you may have something stuck inside your drain pump. The hose coming the bottom of the tub to the pump has a cup inside of it that will catch items left inside clothes. If youd can remove water, remove hose and clean the cup inside. Reinstall and that should correct the problem.
