Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
I have the same problem with mine. There isn't a fluff filter that you can get to easily. When the engineer came to fix something else he showed me this big tube thing inside the machine that had the inside coated with fluff. The machine wasn't very old and I only use the dryer for underwear (apparently towels make it much worse). So ... you'll have to get someone to dismantle the machine to get to the fluff. I was wondering if it is covered by the guarantee because it is ruining my washing.
Because it is a washer dryer, there is no fluff filter to clean.
It is self cleaning, because the fluff is washed away by cold water entering the condenser and flushing the fluff away.
Trust this answers your query.
Please rate my solution.
Thankyou.
The dryer part of the appliance does not have a seperate filter to clean as such, as the fluff and lint is cleared away by a constant supply of cold water coming in on the drying cycle.
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
