Sylvania LC420SS8 LCD TV Logo
Yvonne Walker Posted on Apr 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant get volume on TV
Unable to get a sound. Is there a simple solution?
Mike M
Level 3:
  • Sylvania Master 3,349 Answers
  • Posted on Apr 04, 2014
 Mike M
Sylvania Master
Level 3:
Answers
3349
Questions
0
Helped
686843
Points
16707
Connected to what source?
I cannot get sound from the tv to my surround sound system using line out on the tv
Make sure your tv volume is turned up loud enough to hear through your stereo.
Or if your tv's REAR AUDIO OUTPUT LEVEL is set to FIXED, then make sure your stereo's volume is turned up enough too.
Just some simple tips, but everybody forgets once in a while.
Good luck.
The main menu setting keeps coming back on, unable to use cable 1 or turn to a different cable or channel. (Happened only after power surge) Already tried to re connect the TV, in the main menu setting we...
Hello
I have actually seen this before. The tv in my living room did it and it was a simple fix. I had to download the latest software. Put it on a usb key. Turn the tv off... Stick the key in and load the new software.
The only TRICK was that I had to hold down the VOLUME - button on the tv itself while my wife worked the remote.
So, if you can hold down your VOLUME - button and do things to your tv I would think this might work for you too. I know it sounds strange that a software upgrade can fix this, but it did for me.
Hope this helps
3helpful
RCA 20F512T, unable to get sound on tv. It worked
check in menu, enter in the audio setup and check if tv speaker is in on.
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
1helpful
. unable to lower or raise volume, comcast remote on olivia tv
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
Wharfedale LCD3210HDAF blank screen
Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
Sound Card Problem
click on start go to control panel
click on sound and audio devices
make sure that the mute option does not have a check mark next to it
and put a check mark in the box which says place volume icon in taskbar
click on apply
then ok
then check if you get a volume icon and do check the sound
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
