20 Most Recent RCA 20F512T 20" TV Questions & Answers
Cannot receive local tv channels with antenna. was previously fine with cable hookup.
Check and replace the tuner. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
1/18/2016 3:35:57 AM • RCA 20F512T 20"... • Answered on Jan 18, 2016
No standby light has a ticking sound
Check and replace damaged component/s at its main power supply regulator board and horizontal scan output section circuit. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
10/16/2013 9:52:42 AM • RCA 20F512T 20"... • Answered on Oct 16, 2013
Tv does not power on
Do a Hard Reset. Unplug the power cord and cable for 4 hours. If the power protection circuit has taken over the set due to some shorted conditions internally, then the hard reset should allow you to turn it back on but if the condition remains, it will just go into auto off again. This means there is a hardware problem that is locking up the protection circuit. Since there are so many possible areas in the set that can cause this, you will need a service tech to do the hands-on diagnosis for it.
5/3/2013 5:42:49 AM • RCA 20F512T 20"... • Answered on May 03, 2013
Rca 20f512 tv won't stay on
Here is a troubleshooting guide for you: • Flyback Transformermust have supervision of a qualified service technician
9/24/2012 2:29:21 AM • RCA 20F512T 20"... • Answered on Sep 24, 2012
Black box center of screen
It sounds like closed caption is turned on in the text mode, go to the menu and turn off closed caption.
8/19/2012 2:24:25 AM • RCA 20F512T 20"... • Answered on Aug 19, 2012
Dog ate remote where
Hello
If you want to get its original model remote control; you have to contact the nearest RCA authorised service center at your town. You can't buy its orignal from nowhere else. A universal RCA remote control will work with it, but sometimes some buttons of it may not synchronised. So try to get its original model. Moreover, if by anyway this set happened to be in FPA lock, you cannot open the lock without the orignal remote control. A universal remote control, whatever it may be, won't work then. OK.
9/24/2011 3:36:49 PM • RCA 20F512T 20"... • Answered on Sep 24, 2011
My tv is not working
Press the TV button on the remote, make sure the TV is plugged in, check the electrical outlet to make sure it is live if the TV does not turn on. If these actions do not solve the problem, press the Power button on the front of the TV. If the TV turns on, replace the batteries in the remote control and reset it by pressing the number 1 button for 60 seconds. If necessary, reprogram the remote.
Unplug the TV for two minutes, then plug it back in if the buttons on the remote don't work. Make sure the remote is in TV mode.
Change the settings on the sleep timer if the TV turns off unexpectedly. Unplug the TV and wait five minutes before plugging it back in if necessary.
Check your antenna connections and cables if the sound is okay but the picture is poor. If all the connections are good, adjust the sharpness function.
7/21/2011 4:27:04 PM • RCA 20F512T 20"... • Answered on Jul 21, 2011
I don't know how to
the picture is not showing but the red light is on next to the power button.
7/21/2011 3:53:11 PM • RCA 20F512T 20"... • Answered on Jul 21, 2011
Is this model, RCCA 20f512t, a digital model?
No,This tv is a CRT tv-(Tv Tube).All small tvs with CRTS design are analoge tvs.Tv must have a Converter box to convert for analoge tv to DTV signals to recieve for free broadcasting DTV tv stations signal.Must have pay signals like satalite Dishes,Cables or Telecoms signals.This tv can be use without a Converter box.
7/2/2011 7:40:25 PM • RCA 20F512T 20"... • Answered on Jul 02, 2011
How to unlock FTA?
Hello
you must have its original remote control to unlock the set. If you haven't its original remote handset with you, try to borrow it from any of your friends or relatives who owns the same model. After unloking it, you can use universal remote.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET OK.
6/25/2011 2:32:23 PM • RCA 20F512T 20"... • Answered on Jun 25, 2011
Can you turn off the FPA lock without an original
If you remember your pass word then you can use any remote that operates the TV to reset the menu selection. However if you don't remember the password, then sorry, the original remote must be used.
Below is the procedure to set up the menu for front panel lock, unlock and the password reset.
Front Panel
Selecting this option lets you lock (disable) or unlock (enable) the TV's front
panel buttons. The remote still tunes to any channel so remember to remove
access to any remote that can operate the television.
1. Choose Parental Control from the Main Menue and press the OK button.
2. Enter your passworcd.
3. Press the down arrow to highlight Front Panel.
4. Press the right or left arrow button to choose unlock (_) or lock (_).
I don't remember my password and I want to unlock the TV
If you forget your password, you must reset it. Make sure the TV is of. Press VOL- (down) on the TV's front panel and then
CLEAR on the remote for approxhnately 5 seconds. The TV turns on. Enter a new password next time you access
the PARENATAL CONTROL menu or the TIME_menu.
2/18/2011 6:21:17 PM • RCA 20F512T 20"... • Answered on Feb 18, 2011
When i turn on the tv, it makes a high pitched
hi there !
what You'd just heard was the flyback singing or the High frequency whistle at the high voltage section of your tv set it is located inside, Replacement of defective component will do solve your problem, thank you
2/7/2011 8:09:08 AM • RCA 20F512T 20"... • Answered on Feb 07, 2011
H0w DO I UNLOCK AN
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds.
Ok
12/14/2010 6:03:09 AM • RCA 20F512T 20"... • Answered on Dec 14, 2010
I have a RCA mod. 20f512t cx51 20" flat screen tv.
Hello
There is some short circuit on the circuitboard of your TV. The smoked transistor like device is a low voltage regualtor integrated circuit [IC]. There is no 5VDC rail on the circuit board. The component you specifies may be a 5VDC regulator. If it is so, there must be a reason for its failure. Without this 5VDC rail, there will be no standby light. Its system control section won't work, as it have 5VDC to be into. You jusct check for some short on the 5VDC rail. There will be markings on the printed circuit board about the pins of that IC. It will have normally 3 legs, out of which one is marked as input, and other one as output and the third will be ground. You just find the output pin of that IC, resolder it out from the board, and measure there is any input voltage coming to its input pin without replacing it with an other. If not, collow the inout track to that IC, and find out the origin of that woltage. Usually it will come from the any one of the secondary windings of the line outout transofrmer {LOT}. If so there will be a series low value resistor will be there, check it for open. If there is input voltage already, check the output side for any short. In some cases, ceramic capacitors, if fitted across the 5VDC rail has a chance to get leakey, which in turn put a heavy load on the above said regulator Ic, and that may be the reason for its burning. Anyway, there is no 5VDC rail inside the circuit board. Check for it. If you wants any more clarification, ask me through Fixya, stating your findings, and your doings. OK
11/24/2010 5:51:02 AM • RCA 20F512T 20"... • Answered on Nov 24, 2010
Sound went out
The problem is related to sound output section, or speaker. If the sound went out while working; speaker has out. Sometimes Ic related to sound output may be damaged. Some socket problems also may arise. If the picture is Ok the sound related problems are due the above said reasons.
10/14/2010 8:42:42 AM • RCA 20F512T 20"... • Answered on Oct 14, 2010
I got my 20 tru flat rcathe problem is wen i want
try to get to the menu's with the remote, then with that go to the locked section or security. look for front panel access or something along those lines and enable it.
6/25/2010 2:43:44 AM • RCA 20F512T 20"... • Answered on Jun 25, 2010
Tv code
you try these code#ooo.#027. #089. #090.#190. #103.#240. .... lot more. good luck!
5/17/2010 3:12:32 PM • RCA 20F512T 20"... • Answered on May 17, 2010
RCA 20F512T, unable to get sound on tv. It worked
check in menu, enter in the audio setup and check if tv speaker is in on.
4/21/2010 12:49:22 PM • RCA 20F512T 20"... • Answered on Apr 21, 2010
RCA 20F512T 20" TV Logo
60 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
