20 Most Recent Sylvania SRT2232S 32" TV Questions & Answers
Innovage jumbo remote locked up my sylvania tv
I suspect you have simply switched to an unused input. If you use the original remote you can probably switch the input readily back to what you want. Dave
7/4/2017 10:58:13 PM • Sylvania... • Answered on Jul 04, 2017
Why does it keep switching through all input modes?
Main board fault. Check and replace it. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
10/23/2015 11:26:09 AM • Sylvania... • Answered on Oct 23, 2015
5answers
Codes for sylvania tv
Why to ******* yourself with codes, installing etc. I order this Movie Software before a month, and I can tell it is awesome. Take a look
4/27/2015 10:33:16 PM • Sylvania... • Answered on Apr 27, 2015
I bought a used TV 32 inch with no remote. I hooked up and the picture is small. How can ingest it to full screen without remote
Without a remote control; you can't do any further adjustments. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
10/11/2014 2:10:44 PM • Sylvania... • Answered on Oct 11, 2014
0answers
Sylvania tv codes
Be the first to answer 5/27/2014 3:18:23 AM • Sylvania... • Posted on May 27, 2014Be the first to answer
Can,t program remote
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
3/31/2014 5:37:23 PM • Sylvania... • Answered on Mar 31, 2014
Samsung HL-S5687W HDTV. TV turns on for a few seconds then turns off. No lights on the front blinking but it did make a whirring sound when it was turned on then went off. Could it be the color wh
Horizontal scan output section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
3/22/2014 6:05:37 AM • Sylvania... • Answered on Mar 22, 2014
DON'T HAVE THE REMOTE NEED TO FIX COLORS
As there is no 'Menu' button on the front panel of the TV, you should have a remote control, to adjust picture settings. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
1/19/2014 7:19:05 AM • Sylvania... • Answered on Jan 19, 2014
Can't find the codes for a slyvania tv lc321ss9b
0029,0022,0026,0281,0288,0280 are the common codes to be used with Sylvania brand TVs. If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
1/9/2014 10:34:50 AM • Sylvania... • Answered on Jan 09, 2014
0answers
Srt2232x weight
Be the first to answer 1/8/2014 3:49:01 AM • Sylvania... • Posted on Jan 08, 2014Be the first to answer
0answers
Tv comes on but won't stay on until you turn it on
The main power supply regulator board has the fault. The starting voltage might be faint. Contact any service technician. This is not a user repairable fault.
10/7/2013 3:06:28 PM • Sylvania... • Answered on Oct 07, 2013
0answers
Lost my tv code and my book. Help
Codes to check with Sylvania are: 2327 2304 2314. If you wish to get more, check these sites. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
9/5/2013 6:51:24 AM • Sylvania... • Answered on Sep 05, 2013
I have a Sylvania TV, Model SSC132. I lost the
Try these codes:1004, 1006, 1008, 1019, 1062, 1068, 1069, 1075, 1076, 1077, 1088, 1116, 1130, 1132, 1134, 1161, 1183, 1189, 1196, 1353These are the codes for Sylvania TVs.Check this web page for instructions:http://www.eliztech.com/remotes/rca-prog-v2.php
8/28/2013 8:38:26 PM • Sylvania... • Answered on Aug 28, 2013
2answers
Picture is too wide for the screen can`t see all info on program guide on left side
you are viewing in16:9 ratio (widescreen) and your tv is 4:3 you need to change your picture settings in the tv menu
8/1/2013 3:58:43 PM • Sylvania... • Answered on Aug 01, 2013
I have a Sylvania SRT2232X I want to go up to channel 151
Refer its user manual for details. It has all. If you haven't it, download by this link.
2/22/2013 5:35:17 PM • Sylvania... • Answered on Feb 22, 2013
Sylvania SRT2232S 32" TV Logo
131 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
codes sylvania tv
  • Televison & Video
