20 Most Recent Emerson EWF2004 20" TV Questions & Answers
hi,
you cant.
your going to have to get a mid priced universal with extended features. read the packaging. thrift stores sometimes have a bag wall with old remotes so if you have someone who goes to the thrift store sometimes tell them to start looking for either a vcr or tv remote that says emerson on it for you. directv and dish network universals have video input buttons, if you have eith of those providers go to their website, download or find the chapter where it shows how to set up your viseo input. it is shut off by default..
jm
Emerson EWF2004... | Answered on Dec 31, 2018
Hi, I brought a EmersonTV model EWF2004 without a remote control and I can't find the AV channel to watch DVD's I hope you can help me
Emerson EWF2004... | Answered on Feb 20, 2018
please change your optical lens this a most common problem of all dvd player. bad optical lens always no disc on screen when loading disc, even cd's are new.
Emerson EWF2004... | Answered on Jan 25, 2018
Hello
Three digit universal remote code for Emerson are:-
002 003 004 005 104 105 106 115 204 205 206 213 304 305 316 319
405 502 505 506 519 604 605 705 804 805 903 904 905 906
009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit universal remote code for Emerson are:-
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Emerson EWF2004... | Answered on Dec 26, 2017
change the input back to what it was before he got ahold of it .
Emerson EWF2004... | Answered on Sep 13, 2017
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Emerson EWF2004... | Answered on Jun 01, 2017
switch to AV mode on your TV from the buttons on tv and it will play
Emerson EWF2004... | Answered on Jan 04, 2017
What app do i need to download
Emerson EWF2004... | Answered on Dec 10, 2016
Older sets had vertical and horizontal size controls. If you have the horizontal size control, turning it counterclockwise will reduce the size of the picture horizontally and reduce the overscan.
Emerson EWF2004... | Answered on May 11, 2016
Google it it will give you a list of codes to match up just say coded for what ever it is you need to google
Emerson EWF2004... | Answered on May 04, 2016
For what type of t.v more info is needed or Google your remote type and put universal codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Emerson EWF2004... | Answered on Feb 29, 2016
if do you wanna tell me what tipe of remot you have... i have some book for universal remotes...
Emerson EWF2004... | Answered on Feb 26, 2016
Codes are stored in the remote. If you use a universal remote you can try its code search (or equivalent) feature to find something that will manage some or all functions of your TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Emerson EWF2004... | Answered on Feb 11, 2016
According to my information this TV does not have any published universal codes as of yet. A call to the manufacturer results in:
" Just use the remote that came with the TV...it's too new to have the codes yet"
Not very helpful are they? IT's a nice Tv for the $$..guess customer support is sacrificed when we try to save some $$.
Codes are in the remote.
Emerson EWF2004... | Answered on Jan 29, 2016
search Google make of TV and remote codes usually works
Emerson EWF2004... | Answered on Jan 09, 2016
Check the power supply for bad caps.
Emerson EWF2004... | Answered on Jun 21, 2015
Emerson EWF2004 20" TV Logo
339 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
enter service menu emerson ewf2004 crt
  • Televison & Video
