Press numbers display syntax error how solve a problem?
The order in which you are entering numbers and operations is not correct. For example, if you enter 5++2 most calculators will flag this as a syntax error.
On some calculators you calculate square roots as follows: 25 [SQRT]= gives 5. That is the correct syntax for this type of calculators.
For the newer ones you press the SQRT key and see displayed the square root symbol followed by a left parenthesis. You enter the number, close the right parenthesis, then =. If you do not respect the order you get a syntax error.
I cannot say more because I have no idea what you were trying to do, and more importantly, I do not know the make and model of the calculator.
