20 Most Recent Sharp ELW535 Calculator Questions & Answers
2answers
I have the sharp model
To change from fraction to decimal, all it takes is a keypress. (change key).Not all decimal results (approximations) will be converted to fractions.Anyway, if you want to set the calculator to display decimal results only, Press SETUPPress 2:EDITORSelect 1:LINE.
5/16/2017 5:26:52 AM • Sharp ELW535... • Answered on May 16, 2017
I divide numbers that dont go evenly into each other and it rounds the answer to the nearest whole number. how do i stop this?
Hi there, Press SETUP and and choose 1 for FSE. Then choose 3 for NORM 1. This should fix your problem. If all else fails there is a reset button on the back of the calculator.
11/26/2014 2:28:34 PM • Sharp ELW535... • Answered on Nov 26, 2014
How do I carry an answer over. For example say I calculated 34(3+6)=ANS. now I want to do -log(ANS)^2.how do I put the previous answer in the brackets.
Hi there, Type in - log ( then press ALPHA and the = and ANS will appear. Then continue with the the input as normal.
11/26/2014 2:25:40 PM • Sharp ELW535... • Answered on Nov 26, 2014
This calculator is really confusing, i would like to know how to use its trig functions
Hi there, To use the trig functions simply press the button with the trig function you want and then type in the value of the angle. If you want to add or subtract thing within the angle remember to put open and close ( ) brackets around the angle. If you have any other calculator questions dont forget to check out Welcome to Maths at SHARP Maths at Sharp The website also has a manual available to download.
11/26/2014 2:19:53 PM • Sharp ELW535... • Answered on Nov 26, 2014
Calculator adds or subtracts "k"
Hi there, this means that it is doing a constant calculation. To prevent this from happening you need to press the ON button between your calculations. But dont worry, if you want to go back and view previous calculations simply press the up arrow key and all of your previous calculations will still be there!
11/26/2014 2:14:29 PM • Sharp ELW535... • Answered on Nov 26, 2014
Calculation decimal mode
Hi there, To change your answer to a decimal answer press the button that says CHANGE.
11/26/2014 1:33:58 PM • Sharp ELW535... • Answered on Nov 26, 2014
2answers
Hi I have a sharp
11/14/2014 10:39:04 AM • Sharp ELW535... • Answered on Nov 14, 2014
2answers
How do i clear the
Press [SHIFT] [PLUS] to activate the Decimal numeration mode (>DEC). The p in display (for PENTAL) should disappear.
10/1/2014 8:15:08 PM • Sharp ELW535... • Answered on Oct 01, 2014
I am trying to figure out how to do this question
type in 112.6 then second function and the ln button (you will see above it in orange the e to the power of x in orange). On your screen an e with a little block appears above it. Type in 0.125 open brackets ( 3 close bracket ) equals and the answer should be 163.8320333. If you have anymore questions there is a dedicated website http://www.mathsatsharp.co.za/ where you can leave questions about the SHARP calculators on the student page and they will be answered within a week maximum.
1/17/2014 7:39:53 AM • Sharp ELW535... • Answered on Jan 17, 2014
Where is the probability button?
The EL-535 can generate random numbers for you. Press 2nd Function, 7. You will see random written above 7 in orange. This will give you four choices for random numbers. 0:RAND - random decimals to 3 decimal places 1:R-DICE -1 to 6 like a standard dice, 2:R-COIN - 0 or 1 and you decide which is heads or tails.3:R-INT for integers up to 99
1/17/2014 7:38:58 AM • Sharp ELW535... • Answered on Jan 17, 2014
How do I get subscripts
Unfortunately, you cannot get subscripts on the EL-535. It is not an algebraic calculator.
1/17/2014 7:37:15 AM • Sharp ELW535... • Answered on Jan 17, 2014
2answers
1/1*2+1/2*4+1/2*4*6
According to the operation priority rules1/1*2=1*2=21/2*4=(1/2)*4=21/2*4*6=(1/2)*4*6=12The result is 2+2+12=16If you have a series with increasing denominators then you should use parentheses to force the calculator to do as you intended.1/2+1/(2*4)+1/(2*4*6)or 1/2 +1/2/4 +1/2/4/6=31/48 or 0.645833333.....3
1/17/2014 7:35:37 AM • Sharp ELW535... • Answered on Jan 17, 2014
I got my Calculator in degree mode but the inverse trig functions are still not working what do I do?
If you mean that the calculator is giving you an error 2 it means that the value cannot be correct, for sin and cos you can only enter numbers between -1 and 1. If it is giving you the incorrect answer, make sure that the question is not actually in radians and that you are entering the amount in correctly. If you have anymore questions there is a dedicated website http://www.mathsatsharp.co.za/ where you can leave questions about the SHARP calculators on the student page and they will be answered within a week maximum.
1/17/2014 7:34:10 AM • Sharp ELW535... • Answered on Jan 17, 2014
How do i calculate a P value
By P value, do you mean permutation, or do you mean the statistics p value? To find the permutation P value simply type in the n (or total number of observations) then press 2nd F (the orange button) and then enter the number of spaces available and press equal.
1/17/2014 7:30:05 AM • Sharp ELW535... • Answered on Jan 17, 2014
How do I enter a algebra problem
To enter your equation press 12 then a/b (the fraction key). 12 will now be at the top of your fraction and there will be an arrow blinking in the bottom block. then press 2. If the part in brackets is also meant to divide into 12 then simply press open bracket ( 6 - 7 + 4 close bracket ) right arrow to get out of the fraction and then x 2. If the part in brackets is not meant to be divided into 12 then press the right arrow key before typing in the open bracket ( 6 - 7 + 4 etc. If you would like more help, there is a dedicated website http://www.mathsatsharp.co.za/ where you can leave your questions in the students section and they will be answered within a week.
1/17/2014 7:14:27 AM • Sharp ELW535... • Answered on Jan 17, 2014
How do I input a problem using log
What does it give you? What is this 10exp11? If you want to enter 7.8X10^11 type it as 7.8[EE]11. [EE] is the key [Exp[, or [EE] or [x10X]. The EE is a short cut for *10 to a power. The 10 must not be appear in the expression entered.
11/20/2013 3:00:59 PM • Sharp ELW535... • Answered on Nov 20, 2013
Sharp ELW535 Calculator Logo
69 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
make calculator two decimals
  • Office Equipment & Supplies
