Curtis-Mathis CM32010 TV Logo
g
george lauterbach Posted on Mar 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need the 3 digit code for curtis mathis
Need the code to program with cable box
Level 3:
Top Expert:
  • Curtis-Mathis Master 76,851 Answers
  • Posted on Mar 15, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008380
Points
237762
028,022,027. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too.
http://electro-medical.blogspot.com/
5 Related Answers
Anonymous
  • 4090 Answers
  • Posted on Jun 09, 2010
SOURCE: Philips universal remote needs code for Curtis
Try these
Curtis Mathes
0047 0466
0016 0054
0060 0093
0145 0030
0154 0451
0166
Please rate my help++++Thanks for using FIXYA
joboo1
Jim London
  • 257 Answers
  • Posted on Jan 29, 2009
SOURCE: SCREEN SIZE
Hi, As indicated by your model number the screen size is 27 inch, which is a common diagonal measurement. This TV has a standard aspect ratio of 4:3.
Anonymous
  • Posted on Jun 20, 2009
SOURCE: converter box attach to a 1985 curtis matis tv with built in rabbit ears on top of tv
what is the brand of curtis mathis tronics..?
Anonymous
  • 144 Answers
  • Posted on Jul 09, 2010
SOURCE: I have a curtis Mathis flat screan television and
Since I can't find anything about your set except the fact that it's an older set I suspect that the trouble lies in the fact that Fios won't control a set this old. I do believe this one has an analog tuner which is now obsolete.
Regards
bshldn
Loretta Northcutt
  • 736 Answers
  • Posted on Aug 20, 2010
SOURCE: Have a Curtis Mathis TV
You will need a converter box for this television.
I have an old model Curtis Mathis TV and cannot find the code to program my remote. Do you have Curtis Mathis codes at all?
Have you tried downloading the user manual for the TV model you have if there are codes for the REMOTE it should tell you .
1helpful
Codes for curtis mathis tv
Hello
Check with these setup codes.
006, 016, 026
OK.
1helpful
Program dish remote to my curtis mathes tv .
Hi rosecorbin,my name is Mike Houston of DISH Network and I wanted to give you the codes toprogram your remote to your Curtis Mathis TV. The codes are; 516, 573, 680,652, 665, 667, 668, 670, 674, 659, 590, 650, 664, 708, 641, 645, 703, 712, 526,660, 654, 658 and 506. You will need to push and release the TV button and pressthe 3 digit code and press the # button, I will also leave the steps for a PowerScan. http://www.dishnetwork.com/SupportSection/sat-autotune
I have a universal remote control that I want to use with my Curtis Mathis TV. What code do I need to use to make the remote compatible with the TV?
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
I have a curtis mathes/tronics tv Made in May/2001 Serial no#CM19022S I am trying to hook up a digital conventer box to it and I am having troubles. I also need a users manual for this model and year, pls...
No need for the tv manual.Just follow the basic hook up instructions in the booklet came in with the Converter box.Very easy use channel 3.Use the codes for Curtis-Mathis tv in the booklet for the remote.I hook this Exact model of tv is take 20 mins.
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
27helpful
4answers
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Curtis mathis universal control code for 13 in tv cm13102
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Thomas Perkins
Thomas Perkins
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
