20 Most Recent
Curtis-Mathis CM25011 25" TV Questions & Answers
I have 54 tv telefunken model No. MR701, ineed to
My MR701 Telefunken TV set does not want to switch on with its remote control.When I switch of the plus nad then on again. It switches on and a sign with the key and wording MENU appears after few seconds it switches off again.Some times it does swtch on with a universal remote. The red light where the sensor is keeps on lickering when its on standby.Under normal circumstances it stays red without flickering when the TV set is
on standby. Please help.
There appears a solid black in the lower one third
It sounds like the captions for the hearing impaired is active, get remote and select menu, scroll down to captions, right arrow 1,2,3,4,off, make sure cursor is over off and press enter on your remote and should restore normal function to the set, some remotes have the caption button that is separate from the menu.
I have a universal remote
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Sound no picture
more than likely your picture tube is burned out. not worth replacing can buy a new one cheaper
The tv screenj went white
This is the best solution for your problem as a 40 year experience with wires etc.
Go to the source of your cable signal connector .
Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires.
Vitally
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
Maths
X=25-y
4(25-y) + 5y=56
100-4y+5y=56
100+y=56
y= -44
x=25+44=69
x=69 y= -44
Television
Sometimes if the screen was affected by magnets it will fade. you could try placing magnets around the screen and moving them around, BEWARE you could make it worse. If it dosent fade youve had it........Sorry
