20 Most Recent Curtis-Mathis CM32010 TV Questions & Answers
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Curtis-Mathis... | Answered on Aug 03, 2018
any user manual online ?
unplug from wall
see if remote will get you to system settings audio
Curtis-Mathis... | Answered on Apr 06, 2017
U have a RCA AV component cable R,Y,W just hook that up for the out for the VCR-out put holes and the other end of the cable R,Y,W just hook it up TV-in input holes.That it,now put TV in Video 1 or 2 and play the VCR- VHS tape.Look in ur Phone book Yellow pages.Tv repair,any tv shops can do the CRT-tv analog tv repair.
Curtis-Mathis... | Answered on Jan 08, 2015
028,022,027. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too.
http://electro-medical.blogspot.com/
Curtis-Mathis... | Answered on Mar 15, 2014
Check the format of recording on the disc you inserted in now. Check with an other known disc, and see the result. If both shows the same fault, check the picture setting by entering DVD menu.
Curtis-Mathis... | Answered on Dec 11, 2013
These lines are called vertical retrace lines. Thin white lines will be seen the entire screen, at about one inch apart or so, and will be slightly standing position. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Reason and repair to this fault is described in detail at one among the posts.
Curtis-Mathis... | Answered on Apr 06, 2013
There is some fault with the control section to volume circuit. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Curtis-Mathis... | Answered on Feb 11, 2013
http://www.fixya.com/support/p13832-curtis_mathis_cm32010_tv
Curtis-Mathis... | Answered on Apr 20, 2012
Hello
Check with these setup codes.
006, 016, 026
OK.
Curtis-Mathis... | Answered on Oct 28, 2011
Hi
Setup code for Curits Mathes Tv with RCA RCR 311B unversal remote control is,
1078
OK.
Curtis-Mathis... | Answered on Jul 14, 2011
Can you provide more detail for me? I need to know if this is your main TV by the receiver, or a secondary one. What kind of cables are you using? Also what exactly is happening when you hook this up? Feel free to email me at daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Curtis-Mathis... | Answered on Mar 29, 2011
Tv have 3 colors guns like R,G,B colors.Tv is missing one of it color gun.Have a soldering iron and a roll of solders? Take the tv aparts,resolders the video board soket pins holes that connected to the CRT-(tv tube).Resolder the Yoke wires like R,G,B connected to the main board too.Will solved this problems.
Curtis-Mathis... | Answered on Mar 16, 2011
Curtis-Mathis CM32010 TV Logo
68 questions posted
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Vitally Alcher
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Curtis-Mathis Televison & Video
Most Popular Question
curtis mathes tv remote control codes
  • Televison & Video
