The first link is to a specific manual. The second is to the Emerson Dixell site where there is support and resources. If the site does not provide what you need, try googling by brand plus model plus troubleshooting.
BH 33 signifies that your body controller AKA bulkhead module has an issue. It points out that a fault code was logged - if you scroll to the next screen, you can see the actual fault code.
Likewise, the ENG 0 code is an engine code. Problem is, there are over 2,000 of them. You need to check the diagnostic section to know more about the code on display.
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed per wiring diagram before performing the following steps: STEP 1 Power off and wait 5 seconds. STEP 2 Power on and wait 5 seconds. STEP 3 Press the following keys: CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1 STEP 4 Press START. STEP 5 Make sure Timer ID is the same as the oven. STEP 6 Press CANCEL to exit.
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
3) Best I could find is that folks with P1 error code report tankless fires for short period, and then turns off. This implies air, fuel or vent problem, and can be internal, external or combination.
4) P1 appears frequently on control board descriptors, which might imply the error is control board malfunction.
5) Call Rheem 1-800-432-8373, and then add a comment to this thread and let folks know what you discover.
6) I will also call Rheem when time permits, and post what I discover.
Add a comment for more free help. Also take advantage of fixya expert assistance live. For a price, expert works with you while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
The only brand of universal remote I know of that has a code for Swisstec brand TVs is the Integra - the code is 0880.
The other option is to order a replacement remote for your model TV. http://www.amazon.co.uk carries remotes for a wide variety of Swisstec TVs (note that www.amazon.com does *not* offer these since Swisstec is British).
I hope this helps - please let me know if I can be of any further assistance.
