Probably the relay that switches the water flow between "recirculate/clean and exhaust" cycles. You can confirm by opening the bottom panel and looking at the relay arm. When switching from "washing" to emptying cycle, you will see the relay lever try to switch the flow of the water to the exhaust cycle. Alternately, remove the exhaust hose from the garbage disposal and place it in a bucket or bowl. After the water stops coming out, blow into the end of the hose to see if any food is blocking the hose (sometimes someone operates the disposal while the dishwasher is running and forces food into the exhaust hose.
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
heatman101
