Jacuzzi Tara, Whirlpool Bath  - 8450/Color=Oyster Logo
Celso De Mendona Posted on Mar 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jacuzzi tara o ring
O ring
US Parts Center
Level 3:
  • Jacuzzi Master 719 Answers
  • Posted on Mar 17, 2014
US Parts Center
Jacuzzi Master
Level 3:
Answers
719
Questions
0
Helped
284347
Points
1972
What is the o-ring used for? Where is this o-ring located and what is the function of the o-ring?
US Parts Center
Need indicator rings for 3 controls on U640959 Jacuzzi bathtub. These are flat rings 1.5" ID, 2" OD. The two for the air have 5 circles. Also need the on-off ring.
Good luck Scott Jones...
I've been looking for some specifics on Jacuzzi (seacrest) faucets... for a couple of years...
Since before Jacuzzi moved out of the EAST-BAY area (here) they had pretty good stuff.
I have their "washerless" ceramic faucets..
Through trial & error I've been able to keep these working...
No thanks to the so called "Jacuzzi" (moved out of CALIFORNIA).
Not only were they not helpful when I told them I didn't want their NEW STUFF...
I only wanted to service what I've had for 30 years
(controls sound like what you have)
Try calling these folks... At least they know what JACUZZI used to mean... GOOD STUFF:
Jacuzzi of El Cerrito ... (510-) 527-5547
5327 Jacuzzi St Ste 2c,
Richmond, CA 94804
Toll FREE... Call 888-738-5523
Hope this helps.
Hot Tubs Swim Spas Saunas in California Sales Service Paradise Valley Spas
Jacuzzi Whirlpool Bath JWB 1 2 Air Volume Control Elbow PA54000 U775000...
We can't get it to work. It has worked previously but we don't have a manual and don't know what we are doing wrong. Is there a switch somewhere we need to flick? What is the little hatch with a picture...
If you have a low voltage on and off switch that has gotten water into the switch,even very small amounts of moisture will cause havoc with the micro switches, remove the switch, remove the plug out of the back of the switch and blow dry the switch, reinstall the switch and use sealant.
The controll panel says flo2 and cool and wont turn on or heat up
Sorry for post before ment to hit the clarification. However, did some checking in general and the FLO2 display says this:
"Closed or shortened flow switch on system startup (system disabled). Flow switch in non-functional. This must only be repaired by a dealer or by a qualified service organization."
I hope this helps. Thanks for using FIXYA, good luck. Jeff
Install a inline hot water heater what make and model
any heater will work. find one that is easy to install. Here is a link to someone who sells these. Bath Heaters
Overheating problem
It sounds like the problem is in the main control box. Since the tub shuts down after reaching 110 degrees, the high temp sensor is doing its job. This sounds like a job for a qualified professional. Do get a price for the service call as they are usually expensive. Circuit boards start at 200.00 and go up.
1helpful
Air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
We are installing a Tara 8450, and may need to eliminate the tile surround in corner. Is there a trim kit available? Thank you.
i have not seen a trim kit for this application.you may have to rework the corner with tile.chaulk is your best friend.
2helpful
2answers
Jacuzzi tub on/off bezel wont hold switch down
I couldn't find the information you are asking for in the installation manual. I have included a link to the pdf page so you can print it out and look at it in print. On this particular question, I think I would give Jacuzzi a call. They can better answer you question without guessing.
http://jacuzzi.com/pdf/K272000.PDF?SELINSTMANS=K272000.PDF&goinst.x=15&goinst.y=8
Jacuzzi undermount sink
Your sink is clearly made to be undermounted. No trim ring available. With all of the choices now available for sinks and faucets I would recommend that the jacuzzi sink be removed and that you select a new sink and faucet set to your liking. good luck.
No access panel and need to reconnect the vacuum hose
The trip lever is an over flow for the tub to prevent you from over filling the tub capasity and flooding your home.
Mark
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
