If you have replaced the drain pump in your Bosch WAE24463 washing machine and it still doesn't finish programs and shows the error code F18, you can try a factory reset to see if it resolves the issue. Here's how you can perform a factory reset on your Bosch washing machine:
- Ensure that the washing machine is turned off and unplugged from the power source.
- Press and hold the "Start/Pause" button.
- While holding the "Start/Pause" button, turn the washing machine's program selector knob to the "Off" position.
- Continue holding the "Start/Pause" button for about 5 seconds.
- Release the "Start/Pause" button.
- Turn the program selector knob to the desired program and then press the "Start/Pause" button to start the reset process.
Please note that performing a factory reset will erase any custom settings or programs you have saved on your washing machine, so you may need to reconfigure them after the reset.
If the factory reset doesn't resolve the issue and the F18 error code persists, it's recommended to consult the user manual or contact Bosch customer support for further assistance. They will be able to provide specific troubleshooting steps based on the model and error code you are encountering.
