Sewing Machines Logo
S
Sandra Skinner Posted on Mar 03, 2014
Pressure foot won't stay up - Janome Sewing Machines
Jason Depew
Level 1:
Scholar:
New Friend:
  • Contributor 47 Answers
  • Posted on May 15, 2014
Jason Depew
Contributor
Level 1:
Scholar:
New Friend:
Answers
47
Questions
0
Helped
18746
Points
81
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
1helpful
Janome 5124 pressure foot to keeps falling off.
Sounds like the presser foot holder is bad, get a new one.
Tighten the pressure foot
We have a sewing machine that was manufactured by Janome. It is a New Home Deluxe Model. It has very little travel on the pressure foot itself versus other sewing machines. I have learned just by using this machine.... If you need to get the foot up high...all you have to do is reach through and grab the pressure foot and while picking it up(not the lever but the foot itself) turn it clockwise just a touch and it will stay up plenty far enough to get larger or thicker material under it to sew. I hope this helps. Thanks and remember "Be Easy!" Neighborsboy
If you need further help, reach me via phone at https://www.6ya.com/expert/greg_012fb269876eb4b0
Singer SM MN 93234--pressure foot lifter won't stay lifted, falls down. What to do?
sorry can't help you there may be you need it check by a sewing machine mechanic may be a screw is lose and need to be tight.
Apr 14, 2014 • Singer 7422
Husqvarna 500 - presser foot won't stay in the up position
Have you checked the screw on the side that holds the holds unit in place.? If not, tighten that. :)
The pressure foot won't go all the way down
take off side plate and loosen pressure ft screw . it should snap down. make sure the foot stays align wit the needle. u want the foot slot with needle in ctr.
Oct 20, 2012 • Juki TL-98Q
The pressure foot handle is loose and my foot won't go down what's wrong
Grasp the presser foot bar and pull it down. It is likely that the loose bar has jumped off of the cam on the lever. you'll need to figure out how to get in there and tighten it or replace a broken lever.
Good luck.
Oct 11, 2012 • Singer 9900
Feeddog won't move with pressure foot down. I have a Baby Lock BL4-428. I haven't used it in a while. I cleaned it up and oiled it. The feeddog moves when the pressure foot is up but as so
it sound like the feed dog & the presser foot need to be adjusted
so they work togeather,,it's very possible they need to be timed
a sewing machine repair shop can tell you for sure
Bernina 630 pressure foot won't stay up. What do I do?
Make certain that the foot is firmly attached to the bar. If that is the problem (it won't stay in place on the bar) you may need a new or different foot.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
