As with most scanners, place the document in the scanner for scanning. Open the software that you wish to use. Select "File" from the menu and then "Import". Your scanner interface listing should appear. Click on the device to begin your import from your scanner. Your scanner should scan the document and it will appear in your application. Be advised, Scanners scan in a Graphic format. To edit in a wordprocessor you will need some kind of OCR (Optical Character Recognition) Software to convert the graphics into a wordable form for editing.
