Televison & Video Logo
A
Anonymous Posted on Feb 26, 2014
11 blinks shutdown - VIERA Panasonic Televison & Video
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
I had my Smartstart intalled by a dealer. They were able to get the doors to work. but Directed to d them if the doors work then my engine should start after I activate my subscr iption. Well I did and it...
The multiple flashes of the parking lights are shutdown diagnostics:
1. 1 flash is runtime expired
2. 2 flashes is over-rev shutdown
3. 3 flashes is low or no rpm (tach wire)
4. 4 flashes is transmitter shutdown
5. 5 flashes is + brake shutdown
6 6 flashes is - hood shutdown
7. 7 flashes is timer mode/turbo mode manual mode error
8. 8 flashes is neutral safety shutdown ( the remote start control switch is in the off position).
9. 9 flashes is low battery (voltage setting)
10. 10 flashes is alarm triggered
11. 11 flashes is wait-to-start input timed out.
Hopefully, the above mentioned diagnostics will help you determine why your remote starter is not working and you will begin to enjoy the system.
The standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mitsubishi 55'' projection tv model # WS-55909 won't turn on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
1helpful
3answers
Won't turn on
Although the other response is in much better technical lingo, it sounds to me like the television had a high voltage arc which I have seen on quite a few of the sony big screens lately. Usually, it causes a part on the circuit board, (one of many that were listed on prev. solver's list) to fail. This causes a delimma for the repairman, because when they find the bad part and replace it, sometimes it will pop again causing repeat failure of boards and/or parts on the board. Sony is known for having bad tubes on their projection sets, and it can be a difficult repair even for a trained tech. I suggest calling a sony service center in your area, and get an accurate estimate before deciding if replacing the set is the best idea. Hope this is helpful input, Russmann.
2answers
My nokia 3650
mas mabuti dalhin mo nalang sa cellphone re-pair shop para ma re-format yung phone mo'
wala kasing manual resset ang 3650...
Sep 05, 2008 • Nokia 3650
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
Viera Plasma
hello, if you have a waranty for this tv dont wait take it back to the store for a replacement or repair. contac panasonic for details. they offer a free in home repair service but only if your the original buyer and the set is still covered. this is a not easy or a user repairable situation it is a circut shutdown cuased by a fualty power supply or bad internal board, blinking lights mean theres a shutdown circut preventing full power up panel status.11 blinks pana (th50pz77u) = pb board bad or fualty
since the pb board is a small part it may be a quick fix for a service tech and may not be as much as a power supply or other internal board.
in one of my panny service manuals this 11 times blinking indicates a bad pb board this controls the fans and feeds back to the other other circuts if it is bad it cuases the blinking fualt.
blinking times indicate what is wrong with the tv..
since i dont have your model number i cant tell you specifically if this is the problem, the pb board is one of the smallest internal boards . this info is from a service manual for (th50pz77u)
what is your model number?. the tv is blinking this means it is in need of service it is still repairable. sometimes components you pluged in the plasma may cuase fualts
also if your power outlet is not properly grounded or is not correctly wired you may get trouble. there are 12 diferent blinking sequences from 1 to 12
generally a service tech can come out and check it for you and may be able to fix on the spot. if you have a waranty your doing great if not try a service that offers free in home estimate there are many who will give you a free in home estimate and compete for your business..
hope this helps good luck
1helpful
Blinks twice pause blinks 4 times
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:[email protected]
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
