20 Most Recent Viper SmartStart Module Questions & Answers
Viper rpn 7752v battery
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered within seconds u can get the access and it's totally illustrative complete
1/29/2019 9:40:22 AM • Viper SmartStart... • Answered on Jan 29, 2019
2answers
I've had a SmartStart installed on my truck for
is your service plan still active? check mysmartstart.com to make sure it does not need to be renewed. otherwise try calling their technical support line mon-fri. this error message is typically associated with an account issue.
11/13/2015 8:55:48 PM • Viper SmartStart... • Answered on Nov 13, 2015
When i unluck doors the car doesn't make sounds
You should check the manual of your alarm system. there is some settings for silence. lets say if u press to buttons on your remote and hold it for a little wile it might get the sound but if its factory alarm system than might its originaly without sound. but no worries any way if any one will try to brak into your car it will start to scream
4/2/2014 11:55:56 PM • Viper SmartStart... • Answered on Apr 02, 2014
Can not log into my account
Contact Directed Electronics at 1800-753-0800 to fix your problem.
3/3/2014 4:55:25 PM • Viper SmartStart... • Answered on Mar 03, 2014
0answers
Dsm200 drains battery
The DSM is supposed to be on all the time. The current draw should be no more 15 Ma. Is there a question here?
8/17/2013 10:23:31 PM • Viper SmartStart... • Answered on Aug 17, 2013
My car doesn't start when I use my viper remote.
battery is probly bad or weak--testit for 12.6volts-no less--inspect alternator
7/31/2013 9:42:13 PM • Viper SmartStart... • Answered on Jul 31, 2013
How to resolve service light staying on problem
Apparently, there is something that is not receiving power. What is the year, make and model of the vehicle?
7/8/2013 3:33:43 PM • Viper SmartStart... • Answered on Jul 08, 2013
I cant start car with my phone
Smart Start not working?! Was the unit tested for signal strength and proper operation after installation? If so, and the unit works, did you receive confirmation from Directed Electronics with a link to set up your account? Did you activate your account with Directed Electronics? After activating, did you download the app through your phone? If you have done all of the above and the Smart Start still does not work, your next contact should be made with Directed Electronics and the installer. **Please Note** Downloading the app without activating unit does nothing. Installing the unit without following the setup and test procedure does nothing.
1/31/2013 6:00:31 PM • Viper SmartStart... • Answered on Jan 31, 2013
When I pull up the status button on my smartphone smartstart. It show's that all of the features as refresh for update. HOW do I refresh them?
It sounds to me like your app has an update available. If you have an iPhone this is a normal occurance. iPhone and iPad frequently get update available reminders. Go to the app store and sign in. It should show all available app updates. At this point, click on update all or, update only the ones you want.
9/12/2012 10:14:52 PM • Viper SmartStart... • Answered on Sep 12, 2012
Just renewed my smart start
I have a fx35 and now all of a sudden my car won't start using my iPhone do I need to reset anything?????
5/20/2012 12:44:34 AM • Viper SmartStart... • Answered on May 20, 2012
Car remote starts by itself
if this is happening during cold weather than its perfectly normal it dose it to keep the coolant in the moter from freezing. you should be able to look in the manual and see how to turn that feture off.
3/9/2011 2:37:03 PM • Viper SmartStart... • Answered on Mar 09, 2011
Hi, I just upgraded my
Are you able to login to your account? Have you selected your vehicle? What specifically is not working?
2/6/2011 5:20:19 PM • Viper SmartStart... • Answered on Feb 06, 2011
How to fix My Directed Electronics Smartstart? I
Is the installed remote car starter one of these models:
  • Clifford: models 1.2, 1.3x, 20.7x, 2.2, 3.3x, 50.7x, 590.2x
  • Python: models 1401, 580, 1601, 872, 991, 592
  • By transmitter type: 1-way SuperCode (RS or Sec/RS), Responder LE (RS or Sec/RS), Responder LC3 (RS or Sec/RS), Responder HD
I downloaded and checked the user and installation guide and neither say anything about what the codes are. I guess they want to charge you to tell you what is wrong. It is possible the code is being thrown by the remote starter itself but without the model number I can't tell you what the code means. If you still have the user guide for the remote starter or can download it, it should tell you what the code is.
12/2/2010 5:33:47 AM • Viper SmartStart... • Answered on Dec 02, 2010
I had my Smartstart intalled
The multiple flashes of the parking lights are shutdown diagnostics:
1. 1 flash is runtime expired
2. 2 flashes is over-rev shutdown
3. 3 flashes is low or no rpm (tach wire)
4. 4 flashes is transmitter shutdown
5. 5 flashes is + brake shutdown
6 6 flashes is - hood shutdown
7. 7 flashes is timer mode/turbo mode manual mode error
8. 8 flashes is neutral safety shutdown ( the remote start control switch is in the off position).
9. 9 flashes is low battery (voltage setting)
10. 10 flashes is alarm triggered
11. 11 flashes is wait-to-start input timed out.
Hopefully, the above mentioned diagnostics will help you determine why your remote starter is not working and you will begin to enjoy the system.
11/26/2010 4:21:09 AM • Viper SmartStart... • Answered on Nov 26, 2010
Why when i start my truck with my iphone i cant
Yes, As I understand it that is the safety protocol.
6/3/2010 2:43:11 AM • Viper SmartStart... • Answered on Jun 03, 2010
Viper SmartStart Module Logo
37 questions posted
Top Directed Electronics Vehicle Parts & Accessories Experts
john h
Arnie Burke
Arnie Burke
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Directed Electronics Vehicle Parts & Accessories
Most Popular Question
just renewed smart start
  • Vehicle Parts & Accessories
