20 Most Recent Panasonic TH-42PZ700U 42 in. Plasma Television Questions & Answers
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
4/10/2017 5:30:08 AM • Panasonic... • Answered on Apr 10, 2017
2answers
Can anyone help pinpoint the issue of red screen on Panasonic TH-42PZ700U?
Plasma TV's don't last much more than 10 years.
1/12/2017 4:47:01 PM • Panasonic... • Answered on Jan 12, 2017
Hello, how do I get out of safe mode on my panasonic plasma tv
If you wish to get some details the check the below added link. http://electro-medical.blogspot.com/
7/7/2016 6:21:15 PM • Panasonic... • Answered on Jul 07, 2016
Blinking 1mm green dot on a new panasonic 55vt60
Where on the tv? The screen? The case?
3/27/2014 12:38:10 AM • Panasonic... • Answered on Mar 27, 2014
TC-P55VT30
Sounds like a panel fault. Contact the authorized service center for Panasonic. Gopakumar Gopalan Google
3/1/2014 1:09:54 PM • Panasonic... • Answered on Mar 01, 2014
Goes off and power light blinks 7 times?
The number of times it blinks is a code as to what the problem is. Go to the Panasonic web site and enter the model number etc. and it should tell you some where what the blinks mean. Different TV Manufacture's have different code blinks. Or you might get through by phone and talk to a tech. Then you will know what to do fron there. Gillight
12/3/2013 6:12:57 AM • Panasonic... • Answered on Dec 03, 2013
My tv panasonictx-32le8cautomaticalygoseoff&ledblinkred&green
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
11/27/2013 1:53:05 PM • Panasonic... • Answered on Nov 27, 2013
Does TH42PV7AZ have blue tooth feature?
Refer its user manual for details. You can see these details at its specification page. www.retrevo.comTry the above link to download the manual for free. google.com/+GopakumarGopalan
11/2/2013 10:53:05 AM • Panasonic... • Answered on Nov 02, 2013
0answers
Red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
6/21/2013 12:16:20 PM • Panasonic... • Answered on Jun 21, 2013
Panasonic Plasma TH-42PZ70042 - female narrator voice on some channels. How do I turn this feature off?
Yo yo, checkidee check this out, before you wreck yourself, cuz big D's in your.... I have Comcast (they named themselves Xfinity without adding any value to the product). Anyways, I have a little stupid set top box from them, and a remote from Comcast. On the friggen bottom of the remote is a stupid little button called "LANG". I press it, and it says ENG or SPA on the bottom left of my TV screen. When it's showing SPA, the annoying narration happens. Sheesh, it annoyed the hell out of me for the longest time.
4/24/2013 6:23:19 AM • Panasonic... • Answered on Apr 24, 2013
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
124 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
need replace
  • Televison & Video
