20 Most Recent Panasonic TH-50PX75U Plasma HDTV Questions & Answers
you have tripped the tv's safety power down feature, try unplugging the tv for 15 mins to an hour then try to turn it back on, if it still ceases to function, the tv will need servicing.
Panasonic... | Answered on Jan 03, 2019
IObit Driver Booster Pro Key with latest Pro 5 setup is shared on this page for download. It is a very useful utility that every computer user must have. Did you know that all hardware components connected to your computer or laptop are powered by Drivers. These hardware components include your graphics cards, printers, USB ports and even keyboards. None of these components would work if you didn't have a driver installed for them.
Panasonic... | Answered on Nov 19, 2018
Probable power supply failure
Panasonic... | Answered on Dec 12, 2017
https://www.manualslib.com/manual/507050/Panasonic-Th-50px75u.html
Panasonic... | Answered on May 11, 2017
If the buttons on the TV -and- the buttons on the remote don't work, then there's definitely something wonky with the TV.
The good news is that the power works and the picture looks good. That rules out a bunch of things. If you don't mind tinkering, replacing circuit boards on TVs is pretty straight-forward -- just take off the back, unscrew the offending board and replace it. You'll have to do a little research to narrow down to the right board to replace -- it might be this key controller board:
http://www.shopjimmy.com/panasonic-tnpa4280s-gs-board.htm
Panasonic... | Answered on May 22, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Panasonic... | Answered on Apr 10, 2016
Well, first your model number is the 42 inch, but I digress...
I had a similar problem with a Viewsonic 27 inch, with the blinking power light on a failed power-up. It turned out that replacing the power transformer was the ticket. However, as I have the 50 inch Panasonic plasma, I know that the transformer is built into the set itself. I'd still suggest that this is what needs replacing though, as this is different from a set being on but having no picture.
Panasonic... | Answered on Mar 31, 2016
I had same problem, called visionquest tech support for how to reset the tv:
Using the remote, press source then 2580.
A menu should appear, go to other settings then choose restore default. Select yes.
It worked for me - hope it does for you too!
Panasonic... | Answered on Oct 16, 2014
Here is a link for english and spanish manuals in pdf format.http://shop.panasonic.com/shop/model/TH-50PX75U?t=manuals&support#tabs
Panasonic... | Answered on Aug 17, 2014
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Panasonic... | Answered on Aug 16, 2014
hardware question see ACE Hardware
Panasonic... | Answered on May 25, 2014
Panasonic TH-50PX75U Plasma HDTV Logo
206 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
tv wont turn
  • Televison & Video
