I need the dish tv code for Vizio so my remote will work. thanks k
SOURCE: Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
SOURCE: can't get the tv/input button to work on dish
Hi there! This is Kimberly Escobar with Dish Network. Just ran across your post and wanted to help. In order to get the remote to possibly work the Inputs on your T.V the remote needs to be programmed to your Vizio T.V. In order to do this we have certain codes that can be integrated into the remote. Some of the codes for a Vizio T.V are 505, 671, and 627. The procedure is press and hold the clear T.V buttton located at the top of your remote until you see all the other buttons light up in red, once they are lid up enter one of your codes followed by the pound key for example: 505#. The T.V button should light up 3 times you can then try the remote to see if it works your T.V
Unfortunately we cannot promise it will completely function the T.V so it might bu that input button does not work. If you need any help please contact us directly at 1800-333-DISH.
We're happy to help you with getting your DISH Network remote addressed to your TV. We're going to start by pressing and holding the TV button on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Vizio TV; here are some of the codes we currently have: 505, 598, 627, 520, and 627. Press the pound (#) button to save the code in your remote. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Vizio TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
