20 Most Recent Zenith ZEN450 Remote Control Questions & Answers
8answers
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
2/16/2018 11:54:28 PM • Zenith ZEN450... • Answered on Feb 16, 2018
Sylvania LD320SS8A error code 3. Power LED blinks 3 times than shuts down
Damaged component/s at it horizontal scan output stage circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ Do a search by type in the brand name of your device at its search box.
6/12/2014 5:16:54 AM • Zenith ZEN450... • Answered on Jun 12, 2014
Need code for LC320SS9A T.V.,
Hello
Setup codes for Sylvania TV with AT&T Uverse remote contol are:
1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465
Proceedings:
1. Power ON the device you want to programme.
2. Press and Hold the appropriate Mode key [TV,DVD or AUX] on the remote control.
3. Whithout releasing the chosen Mode Key, press and Hold OK key simoultaneously.
4. Release both the Mode key and OK key. All the mode keys should flash twice.
5. Enter the four digit serup code by pressing the number keys on the remote control.
The Mode key will flash three times indicating correct entry and return to normal operation. When an invalid code is entered, the selected mode key will give a long flash to indicate that you have not entered the setup code correctly. Should the remote control time-out before you complete the code set-up, you will need to start over.
6. Point the remote control at the programmed device, and press the Power Key once. The device should turn OFF. If it does not turn OFF, repeat steps 2 through 6 trying with next code until you can get the correct code for your set. If the set turns OFF when you point and press Power button, it means that your device have accepeted the code. You may have to spend some time before your device. Note: Be fast as you can when doing the steps otherwise the remote will time-out, and you have to repeat the proceedings. Keep all the settings in mind first and proceed. OK.
8/29/2011 8:23:17 PM • Zenith ZEN450... • Answered on Aug 29, 2011
How/Where can I get a
May I get the model # of the Tv to help you get the right remote control
11/15/2010 8:18:43 PM • Zenith ZEN450... • Answered on Nov 15, 2010
I can't code my comcast remote to my sylvania lcd
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
6/7/2010 9:42:51 AM • Zenith ZEN450... • Answered on Jun 07, 2010
I need remote code for Direct TV to work Sylvania
here are the codes from manual
11864, 10054, 10030, 10171, 11963, 11931, 11394, 11314, 11271, 10587, 10381, 10187, 10096, 10065, 10028, 10024, 10020
12/20/2009 9:00:53 PM • Zenith ZEN450... • Answered on Dec 20, 2009
4answers
Sylvania LC321SS9 remote code
I have the sylvania LC321SS9 tv and a atlas dvr1056 remote code 1864 works great with all functions!
12/10/2009 6:45:01 PM • Zenith ZEN450... • Answered on Dec 10, 2009
The tv screen is blue
Let me inform you - Blue Screen has nothing to do with Remote. This is a Hardware problem. More likely, you need to get it repaired by calling a tech.
Before you call, make sure you have the correct connections. Usually this might occur, if there is no Signals or if you might have Turned DVD/VCD on.Check the manual to turn it off. Also, plug off the cord for 30 minutes and then again plug in the Power cord and see, if that could help you.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
7/24/2009 1:07:22 AM • Zenith ZEN450... • Answered on Jul 24, 2009
Sylvania lc321ss9 and jumbo remote control
807,002,502,115,
520,919,324,247,
402,408,109,715,
717
Took these out of the manual.
Please leave me great feedback, thanks.
7/23/2009 6:51:28 PM • Zenith ZEN450... • Answered on Jul 23, 2009
Need program code for a symphonic tv
www.remotecodelist.com
www.tvcodes.com
www.remote-codes.com
7/9/2009 8:41:30 PM • Zenith ZEN450... • Answered on Jul 09, 2009
Need remote for sylavania tv model srt 2113
I bought a "Universal Consolidator" today for my own SRT2113, and it works like a dream. It's the 15 dollar universal remote you always wanted. Its menu, channel searching, volume, and, yes, the infamous GAME MODE even works (use the input button)!
5/4/2009 4:48:03 PM • Zenith ZEN450... • Answered on May 04, 2009
LC321SS9 remote code and cox remote can not find universal code
I have the same TV and the same problem. I exchanged the Cable remote for a new one and did the auto search. (hold the tv button/Sel key then channel up key) It worked with the new remote. I believe the code is 121
2/12/2009 1:09:24 AM • Zenith ZEN450... • Answered on Feb 12, 2009
Sylvania tv
1st - This remote is not a One For All remote. it is a Zenith remote. ZEN450 Universal
2nd - Everything you need to know about setting up the remote would be in the remotes manual. go here to download it free: http://www.replacementremotes.com/store/productdetailp.cfm?productid=61229
3rd - If none of the codes work, its possible that you may have to get the equivalent to the original remote. The Anderic RR0108UD for Sylvania TVs. this remote will work without programming and will also do the "GAME" input button. This is the best way to go. Simple and Easy, and cheap. go here to see about purchasing it: http://www.replacementremotes.com/store/productdetailp.cfm?productid=27278
11/19/2008 3:10:36 PM • Zenith ZEN450... • Answered on Nov 19, 2008
Zenith ZEN450 Remote Control Logo
47 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
codes sylvania tv
  • Televison & Video
