what is the surgery for
if is not for a leg problem then I suggest that you get to a doctor fast as what you describe could be a blood clot in the leg and that is very dangerous
Try to blow out the computer dust from the case. You MUST dis-connect all power from computer and devices. Take it out on your patio and blow the dust out with the vacuum cleaner, but DO-NOT actually touch the vacumm brush oh the motherboard.
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
there are format settings in your menu. highlight the highest format( 1080) or take it off auto format. this way it always in one format and will not switch even if the programming is in a lower format.
Check to make sure that you have the correct voltage going to the motor. It sounds like you lost one of your legs of power which would give you 110v instead of 220v. Or it could be in the pc board.
or the three legged spider that attaches to the drum. its made of cheap metal and one or more legs can crack or break letting the drum loose - seems like bearing but isn't! cost about £40
