20 Most Recent Hitachi RAS-09UH Air Conditioner Questions & Answers
3answers
Hitachi A/C. The green light of air filter indicator is on.
When its turn off, not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
5/15/2020 4:53:06 PM • Hitachi RAS-09UH... • Answered on May 15, 2020
3answers
Air conditioner stopped working
Check the breaker in the panel and the fuses in the disconnect at the outside unit. If that doesn't do it. call a heating and air technician instead of an electrician.
11/19/2018 3:20:50 PM • Hitachi RAS-09UH... • Answered on Nov 19, 2018
3answers
BROKEN/MISSING HITACHI AIRCONDITIONER REMOTE CONTROL rar-2p2
abhay .hi their is a problem in my remote
10/11/2016 2:16:02 AM • Hitachi RAS-09UH... • Answered on Oct 11, 2016
2answers
Hi my Hitachi Quadricool Win ac cooling does not
service and checked the gas you see ice is coming or not on cooling coil
3/15/2016 5:27:29 AM • Hitachi RAS-09UH... • Answered on Mar 15, 2016
I have a "Hitachi split type air conditioner model RAS- 3098U", and its started leaking today from the right side. I didn't install it and I can't figure out how to remove the front cover to l
water is coming from evaporator drain pan most likely. lots of humidity right now and 1st thing your ac is going to do is remove this from air. most likely cause would be condensation line clogged or if you have condensate pump, then it also could be cause. to remove cover usually you have to remove air filters look for any screws and possibly front louvers pull down. this usually does not give you access to drain pan. unit usually needs to be removed from wall plate and this might involve refrigerant lines being removed, and for that my friend you defiantly want a qualified professional.
9/28/2015 10:13:09 AM • Hitachi RAS-09UH... • Answered on Sep 28, 2015
2answers
Where is breaker located in hitachi split ac
you didn`t told if it is already installed or just going to install.by the way,it has no breaker in it even on outdor unit,the only components that switching in it`s power are relays controled by electronic ckt the.installers of it,they just attaching the hot wire from your DB`s to the a/c switch(20 ampers,35 amperes) and going down to indoor units.your main distribution box has its own load schedule for it`s breaker attached in it.and not in your split type unit.the way of tracing it is look for the label opposite side of DB`s cover and it shows you where of those breakers are loaded by your a/c.
4/23/2014 3:24:24 PM • Hitachi RAS-09UH... • Answered on Apr 23, 2014
Board
what do you mean
1/20/2014 7:43:18 PM • Hitachi RAS-09UH... • Answered on Jan 20, 2014
0answers
0answers
When we switch on the ac it runs for 1 minute and
clean the condenser coil (outdoor).
12/14/2013 6:58:30 PM • Hitachi RAS-09UH... • Answered on Dec 14, 2013
Hitachi RAS-09UH Air Conditioner Logo
138 questions posted
Top Hitachi Heating & Cooling Experts
jws1013
john h
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Heating & Cooling
Most Popular Question
hitachi c green light air filter
  • Heating & Cooling
