20 Most Recent
Dell OptiPlex 170L PC Desktop Questions & Answers
Cuando prendo mi optiplex 170
A: Error DRIVER_POWER_STATE_FAILURE
todos mis drivers est?n actualizados o eso es lo que me aparece al ver cada uno de ellos.
Infxtray.exe- entry point not found
Its a Laptop, drivers are supplied by your Laptop makerspecific to your model
MS Only supplied drivers for its own hardware, eg an MS Mouse/Keybd or XBox
Error code 43 on dell computer
Error code 43 is when a dll sends a message that a blue tooth device has failed. most likely your courdless mouse or keybord is the culprit. try removing it from device manager and reinstalling it.
Forgot password for windows vista
This is totally different from "How to disable password"Lost Windows password:
- Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
- Login as other user (if other user is available) and manage users. Must be an administrator.
- Reformat computer.
- Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
- Login as another user (if another user is available) and manage users. Must be an administrator.
How to reset
control panel, system recovery, it would be easier if you had a OS disc and follow standard reset procedure.
Orange light on Dell GX270 power button
A solid orange light, usually indicates an internal power problem but just in case try reseating the memory. Also its become a habit on a GX270 to check the capacitors to make sure they aren't bulging.
