GSD 6500 and I have the same problem as the owner in #4 below. The soap dispenser door opens approximately 7 minutes into the wash cycle and hits the lower edge of the upper rack, preventing it from fully opening. If I don't open the door at 7 minutes into the wash cycle, I get caked soap left in the dispenser every time. Seems like a design flaw to me! Is there a recall on this model or a solution that elevates the upper rack, a kit or something to adjust the height so the door does not hit the rack?
SOURCE: Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new. That was quite an axccomplishment since the machine is 15 years old.
SOURCE: GE profile model GSD 4120y70BB the second soap
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool and Frigidaire dishwashers use a wax motor to open the soap dispenser; this wax motor does receive 120 volts to work. The plunger inside the wax motor slowly moves and pushes the plunger and door open. This is what a wax motor looks like.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
SOURCE: Soap dispenser opens but does not wash out
a tube in the machine may be cloged act soon because you dont want a flood
SOURCE: Soap dispenser door not opening up
If the soap door doesn't open all the time, remove the outer door cover and remove any obstructions. There are pieces of styrofoam and cardboard inside the door that come loose from time to time, and prevent the linkage from operating freely. They can be re-glued OR eliminated.
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
