Epson Perfection 4180 Photo Flatbed Scanner Logo
Posted on Jun 10, 2009
Epson Perfection 4180 won't scan my negatives
When I start the twain driver of my scanner, the driver refuse changing the document stetting to 'film negatives'.
Another strange thing is the backlight won't go on when I start the scanner.
Can somebody help me with this? I've a bunch of film negatives waiting for me :(
Regards,
Robert
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
531
Points
Cant scan film with epson perfection 4180. how can this be fixed?
Scanning in Epson 4180 perfection - trying to scan slide in home mode - positive film - when it scans the slide in its holder it scans the holder & the slide. What do I need to change?
Make sure the white document matt has been removed from underneath the lid. Then make sure that the document type has been changed from reflective to Film etc. If film is greyed out then check the cable is connected properly from the lid to the base of the scanner.
1helpful
Negative images
Check the settings and try to update the software/drivers if available from manufecturer's website. ([email protected])
2helpful
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
2answers
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
2helpful
2answers
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
1helpful
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Scanner incorrectly reads frame position on film
Yes there is
3helpful
Epson perfection 4990 photo scanner
2helpful
3answers
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
3helpful
2answers
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
