20 Most Recent Epson Perfection V350 Flatbed Scanner Questions & Answers
2answers
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
7/9/2021 8:58:18 AM • Epson Perfection... • Answered on Jul 09, 2021
Clean inside glass
Can be done by opening the top cover careful after removing the tabs and the srews if any.
3/11/2015 11:12:34 AM • Epson Perfection... • Answered on Mar 11, 2015
It takes a long time
When your image is bitmap or higher in size, it does take time to be attached or uploaded to your email. Try saving the file in JPG or have it reduced in size.
3/13/2011 1:10:31 AM • Epson Perfection... • Answered on Mar 13, 2011
Vertical banding (rainbow effect)
You need to scan the prints at the same resolution that they were printed. Otherwise you'll get that screen door effect (moire pattern). I think this effects most scanners. I'm currently looking for a photoshop solution to this problem since I don't have the originals. Not fun.
1/6/2011 4:19:44 AM • Epson Perfection... • Answered on Jan 06, 2011
When I scan a photo
the scan diod will need to be riplaced
8/3/2010 11:55:47 AM • Epson Perfection... • Answered on Aug 03, 2010
3answers
Problems with v350
HI-
Try to reseat or unplug and replug the usb cable for the scanner to your mac, errors indicating that the computer is not communicating with it. you can also go to apple icon then go to system prefences or system profiler, click on hardware then USB check if there is an epson scanner under USB device tree
keep me posted
3/31/2010 5:51:20 AM • Epson Perfection... • Answered on Mar 31, 2010
How do you clean the inside of the glass plate
This is not for the faint hearted. Two screws, phillips head on the hinge, remove. Then very carefully lift up the hinge side and slide out the three square fittings (plastic, same color as case) from the slots. You have to clear the top from the base before you can slide them out. Do this carefully as replacing is more difficult than removing. To replace slide the three fittings into the slots and gently lower. Watch the lip on the hinge side as it need to be inside. Good luck.
3/7/2010 1:03:21 AM • Epson Perfection... • Answered on Mar 07, 2010
How do you scan 35mm negatives to your computer?
That completely depends on the brand and model of your scanner. Many popular scanners today will allow this, although most scanners need an adaptor. They are easily available from ebay, online and many sources, but only if the scanner is made to accept one
9/17/2009 2:32:36 AM • Epson Perfection... • Answered on Sep 17, 2009
I have vertical lines in my photos when i scan them
If the lines are in the same location for all scanned outputs, it is clearly dust on the scanner glass. Clean it thoroughly.
S. Mohan, India
7/9/2009 11:02:28 AM • Epson Perfection... • Answered on Jul 09, 2009
2answers
EPSON 350 scans 1/2 photo, makes loud clicking noise.
The chassis bends very easily on this model and the problem can be caused by scanner not being on a level base supported by all its feet.
6/16/2009 12:43:30 PM • Epson Perfection... • Answered on Jun 16, 2009
Scanner incorrectly reads frame position on film
Yes there is
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
8/22/2008 11:29:20 AM • Epson Perfection... • Answered on Aug 22, 2008
Epson V350 Install Error
what is the exact error message and extension error?
3/26/2008 9:49:08 PM • Epson Perfection... • Answered on Mar 26, 2008
Intermittent scanner problem
What brand of scanner is it?
Check in your Twain settings if you have auto-edge detection enabled. Sometimes this will mistake content on the page for the edge of the document.
10/23/2007 3:01:35 AM • Epson Perfection... • Answered on Oct 23, 2007
Epson Perfection  V350 Flatbed Scanner Logo
Popular Tags
29 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Perfection Epson
  • Perfection Epson
Most Popular Question
vertical banding rainbow effect
  • Office Equipment & Supplies
