Hold in the PTT button while turning on the radio. First it will announce the frequency, then press the monitor button once, then it will announce the code, press the monitor button one time again, then if it is equipped with a language choice, you will get to select your language by using the PTT button to walk through the choices, lock in your choice by pressing the monitor button one time. Shut the radio off, then back on without holding in any buttons... you are ready to use the radio.
Hold in the PTT button while you turn on the radio. It will announce the frequency number. You can use the PTT button to change the number. Then press the Monitor (small possibly red) button to lock in your setting. The next number your radio announces will be the Code. Use the same method to change the code if needed. Then press the Monitor button to lock in your setting. Once you have set both your freq and code you can turn the radio off, then turn back on normally and use the radios.
The CLS1110 is a one channel radio. However the one channel can be changed to another frequency and/or PL code. With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
It is possible you have your PL code set differently between the two radios.
Instructions: Hold the PTT in while turning the radio on, listen for the code to be announced, use the PTT if needed to change the setting, then press the monitor button to lock in the setting. It will then announce whether it is 12.5 or 25k channel spacing. Use the PTT to change the setting if needed. Then press the monitor again to lock it in.
If you need more assistance give us a call. (google our name)
1) Put your radio in programming mode by turning on the radio while holding down the PTT and MON buttons. Continue to hold these buttons until the 'noise' stops.
2) Press the MENU button once. Now, using the + or - buttons choose the frequency number.
3) Press the MENU button to lock in your frequency. This will take you to your CODE. Press the + or - button to choose your CODE.
4) Press your MENU button to lock in your CODE.
5) At this point you can walk through the rest of programming features or simply shut the radio off and begin using it. Note: You will know when you are at the end of the programmable features because it will chirp a different beep than you have been hearing when you've pressed the MENU button to lock in your new setting.
There are several ways:
1) Customer Programming Software (CPS)*
Allows users to perform various programming
functions. Plus, the CPS software provides access
to new features such as Radio Reporting to
manage cloning and radio profiles, Manager Lock,
Power Select, and Time-Out Timers.
* CPS is available as an optional accessory, including required USB cable.
2) Easy Cloning
Quickly copy settings from radio to radio with
either the Radio-to-Radio Cloning Cable or the
Multi-Unit Charger accessories. (Both sold
separately.)
You should be able to purchase any of this software/equipment from your retailer where you purchased the radio.
Commonly called the TalkAbout Basic. With the radio turned on hold in the monitor button. It should announce the current setting. Use the PTT button to change the setting. Press the monitor button to lock in your selection. When done shut the radio off and then turn it back on.
To change channel & code press talk and monitor
while turning radio on.
Radio will speak current channel.
Release both talk and monitor.
Press talk to change to next channel or press
monitor to keep current channel.
Press monitor when desired channel is selected, radio will speak current code.
Press talk to change to next code or press monitor
to keep current code.
Press talk to change code as desired then press
monitor when done.
Will speak channel and code selected.
Set all units in same manner to
communicate.
Setting and Transmitting Call Tones Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk. To set a call tone: 1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays. 2. Press + or - to change and hear the call tone. 3. Press MENU or PTT to set the new call tone or turn feature off.
Looks like you have it in the locked position. We need to unlock it and set the pl codes and channel number the same as the other one.
Locking the Keypad
To avoid accidentally changing your radio settings, press and hold for 3 seconds
or until displays. You can turn the radio on and off, adjust the volume, receive,
transmit, send a call tone, and monitor channels. All other functions are locked.
To unlock the radio, press and hold for 3 seconds or until is no longer
displayed.
Try reading this manual on page 18 to unlock the radio www.starbatteries.com/radiomanuals.html you will find the manual
the last link on the left, a new page will pop up, go down the page a little and click on download pdf 3m.
Hope this helps some, I lock my radios alot so they dont change if I bump them.
Take Care,
Kevin
18http://www.starbatteries.com/radiomanuals.htmlhthttp://www.starbatteries.com/mot5gmfrstwr.htmltp://www.amazon.com/exec/obidos/redirect-to-extehttp://www.starbatteries.com/radiomanuals.htmlrnal-url/ref=mt_mo_view_54570/104-0759567-2439960?path=http%3A//media-server.amazon.com/exec/drm/digital/moleproxy.cgi%3Fname%3DTW90b3JvbGEgVDU1MDBSIEdNUlMgRlJTIFJlY2hhcmdlYWJsZSA1LU1pbGUgTWFudWFs%26file%3DTUFOVUFMMDAwMDczMDMwLnBkZg%3D%3D&append-uid=no
