20 Most Recent Motorola Talkabout T5800 (22 Channels) 2-Way Radio Questions & Answers
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Motorola... | Answered on Oct 18, 2011
Depending on the type of microphone used, if not the type using the speaker as a microphone, it may be damaged. I would though, suggest you remove the battery, open the case and allow the innards to dry in a warm place for several days. Even daily exposure to the sun should work fine.
Motorola... | Answered on May 18, 2010
press and hold the + button untill the frequency changes then move up and down to the one you want.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Motorola... | Answered on Apr 25, 2010
A couple of things you can try:
1. Use electronic contact cleaner (spray type) on the PTT switch;
2. Use an external speaker/microphone and/or handsfree VOX headset
3. Replace the PTT switch. 4 solder points. Might not be easy but doable.
The last would require that you remove the defective PTT switch and use that as per sample when looking for replacement. Some printers uses the same type of switch. Familiarity with electronic components/circuitry, use of a DVM and a soldering iron would also be required.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Motorola... | Answered on Jan 10, 2008
The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency. radiodude365@yahoo.com
Motorola Radio... | Answered on Jun 16, 2019
Turn off your CTCSS or DTS functions. You will have to go into the set up menu for this.
Motorola Radio... | Answered on Jun 04, 2019
Long press P3 and check key sign will be goes OFF, now your keypad is unlock.
Motorola Radio... | Answered on May 31, 2019
You must have the RSS (radio service software) software and the correct cable. There is no resetting without these.
Motorola Radio... | Answered on Apr 15, 2019
Check your battery connections and/or batteries. It sounds like the radio is trying to perform the “power on” sequence, but doesn’t have enough power to actually power on. Use fresh from the package or other “known good” batteries, and clean the battery contacts with rubbing alcohol and a clean paper towel. If there is corrosion or other oxidation on the contacts, you may need to use an emery board and then the alcohol wipe. Beyond that, the radio is not really “user serviceable”. Is there any chance the malfunctioning radio was exposed to water?
Motorola Radio... | Answered on Mar 02, 2019
Radio Compatibility: Which Models Will Work Together - Buy Two Way ...
https://www.buytwowayradios.com/.../radio_compatibility_which_models_will_work...
Sep 11, 2008 - Why won't a Boafeng BF-888s work with a Boafeng ATR-22? ... Can you program a Motorola mag one BPR40 to receive on a BAOFENG BF-888S .how can I . Is it ... Would my Albrecht AE6890 work with Motorola XTN 446?
More info and videos
https://www.google.com/search?safe=off&ei=8odsXJukHOOJggf7nr-ACg&q=Baofeng+bf888s+to+Motorola+XTN
Motorola Radio... | Answered on Feb 19, 2019
there are two things to be check, first volume control need to be check , and if is it OK/read the radio and re check the audio configuration in the cps, and re-try, if still the same , if you have the same radio and know on how to clone?you may clone it, and re-try, if trouble still exist,please, kindly bring it to the nearest shop in your place,
have a great day,
j
Motorola Radio... | Answered on Feb 10, 2019
You must buy Motorola software from Motorola. Get a cable from them also. You also must have an FCC License to legally operate these radios. Your best best is to go through a dealer. The FCC License is quite hard to do without a dealer guiding you. It is easy to be ripped off and you must go through a coordinator. If not USA, still go through a dealer. The software and cable issue does not go away, ever.
Motorola Radio... | Answered on Feb 01, 2019
Motorola Talkabout T5800 (22 Channels) 2-Way Radio Logo
6 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
talk about frequency change
  • Radio Communications
