20 Most Recent Motorola Talkabout T5720 (7 Channels) 2-Way Radio Questions & Answers
Perhaps the monitor button is over-riding a privacy code. Set the privacy code to zero and then try it again.
Motorola... | Answered on Nov 18, 2017
You're not trying to use a privacy code on one radio without using the exact same privacy code on the other radio, are you?
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
Motorola... | Answered on Sep 04, 2016
Look for the user guides here http://shop.giantintl.com/Manuals.asp?offset=30
Motorola... | Answered on Dec 17, 2015
It is possible the manual is wrong where it explains channels 1-7 (GMRS/FRS). When checking on line sources your example frequency on Ch 7 of 462.7125 is limited to .5 watt. http://wiki.radioreference.com/index.php/FRS/GMRS_combined_channel_chart
With this in mind the icon on your radio is correct, and the manual is wrong on page 19. http://shop.giantintl.com/Manuals.asp?
Best regards.
Motorola... | Answered on May 26, 2015
Download it from here: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Motorola... | Answered on Feb 24, 2015
Check your battery. Transmitting takes more energy than receiving. Also, check your frequency and code settings. The radio you are using this one with might have a different code setting than yours. http://shop.giantintl.com/Manuals.asp
Motorola... | Answered on Jan 08, 2015
Here's a link to the user guide http://shop.giantintl.com/Manuals.asp You can lock the keypad.
Here is a link to the user guide page http://shop.giantintl.com/Manuals.asp Select your model from the pulldown.
TalkAbout T5720 is a 1/2 watt radio.
http://shop.giantintl.com/Manuals.asp, use the pulldown to find your model
Motorola... | Answered on Jan 06, 2015
Here's a link to the user guide page, choose your model from the pulldown: http://shop.giantintl.com/Manuals.asp
Contact Motorola Solutions
Get Support
Mark Motorola Mobility Support
Get Support
Mark
Motorola... | Answered on Jan 05, 2015
Scan mode is when you set your radio to scroll through all available channels looking for activity.
Motorola... | Answered on Dec 24, 2014
both radios must be set to the same channel number. There is also a private code number that should be set to the same number on each radio.
Motorola... | Answered on Aug 28, 2014
If it's been that way from the start you should check your settings and adjust the contrast if that feature is available. Your manual or a Google search will provide instructions. If that's not it your batteries could be low as that will sometimes affect the display. Also, on the off chance you are, wearing polarized sun glasses will weaken or block some displays.
Motorola... | Answered on Jul 16, 2014
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
174 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
sync 22 channel motorola 2 way radio
  • Radio Communications
