20 Most Recent
Motorola TalkAbout T5000 2-Way Radio Questions & Answers
Frequency list t5720
Look for your user guide here to find the answer http://shop.giantintl.com/Manuals.asp?offset=30
12/17/2015 12:35:22 PM •
Motorola...
Answered
on Dec 17, 2015
K7gmrcej motorola radio
Parts are not available for this model radio. Speakers generally are damaged from debris or moisture getting into the speaker. They are especially susceptible to small metal fragments due to the magnetic properties of the speaker.
12/17/2015 12:26:10 PM •
Motorola...
Answered
on Dec 17, 2015
Is it possible to put a longer antenna on
yes, but no. The radio is designed for low power and a short antenna to limit range. This was to reduce interference with Licensed FCC radios. Since I will provide a few ideas, these are to experiment with radio waves, NEVER to break the law. So.....ideas to increase antenna: most simple, tape coax to the antenna lead. It will pick up a small amount of the radiated signal and sent it to the longer antenna. Strip the rubber and even the mesh, the center copper sends the signal. Best if under 10 feet. Other than this, you either cut open the rubber antenna or best of all, open the radio and soldier to the antenna connection on the main board. Remember: low power radios cannot send a signal far. Use good quality coax, RG58, never cable TV coax. Short length has a better opportunity of working. 30' you will lost all the signal in the coax. Other ideas? Yep, lots. email us. :)
7/1/2015 11:55:06 AM •
Motorola...
Answered
on Jul 01, 2015
What is !vox
Vox means voice activated, as you speak, it should transmit
4/8/2014 5:49:44 PM •
Motorola...
Answered
on Apr 08, 2014
