20 Most Recent
Motorola Walkie Talkie 2-Way Radio Questions & Answers
Key fail for motorola xts 2500
Sometimes portable radios forget their encryption keys, especially when it takes you longer than 30 seconds to change a dead battery. You may have to either re-flash the key into the radio or else change the software setting from security hardware equipped to NOT security hardware equipped, or else just ignore the key fail warning and realize that your transmission is no longer encrypted like it used to be.
Motorola t5400 one will transmit one will not
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
One walkie talkie has static on every channel
It sounds like your monitor button is stuck and you are hearing the white noise. Try pressing the monitor button on your other radio and see if the noise is the same. If so, your button is stuck. If not...
Sometimes a lot of static can be an indication of a bad or poorly charged battery. To check for this trade batteries with your known good radio and see if it solves the problem.
Broken antenna. Is it
Sorry,but no. The radio is non-repairable once the antenna has been removed.
Best regards.
Receiving signal
Check your private line (PL) code in programming to see if all the radios match.
K7gfv300 manual
Look for the user guide here: http://shop.giantintl.com/Manuals.asp?offset=30
