SOURCE: Oven won't heat even though each component seems to be functional.
Even though the magnetron passed the continuity tests, it can still be bad. In fact, most of them fail in ways that do not show up in continuity tests.
And I am 99% certain yours is bad, especially since you have proven that the filament voltage and high voltage DC is being produced and sent to the magnetron.
I must say that the testing you have done is not recommended for people without plenty of experience, but apparently you did it safely. Please don't press your luck, since the high voltage can be instantly lethal.
For
Goldstar / LG / L.G. parts, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat
8-5 CT) and choose the appropriate prompt from the menu or visit here.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: fuse
The Interlock Monitor Switch is an added
safety check on the Primary and
Secondary Interlock Switches. If the
Primary and Secondary Interlock Switches
allow the oven to operate with the door
open, the Monitor Switch will blow the
fuse.
You can get more information about adjuting the interlock switch from this link
http://136.166.4.200/contents/Microwave/LMVM1935xx/LMVM1935xx_Service_Manual.pdf
sections 7-11 thru 7-12 discuss the door interlock adjustment that will cause the 20A fuse to blow if it isn't set up right. I hope this helps you...
SOURCE: LG MS-2143RSL MICROWAVE OVENT NO HEAT
hi i am suggesting that it is probably the magy as the res to grndis a bit low and therefore loading the sec supply down , just a thought
cheers grant
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
If you are interested in doing it yourself the following link will help : Microwave Repair Manual
(**All the above references to tests are found here)
