Cavs DVD-203G DVD Player Logo
A
Anonymous Posted on Feb 16, 2014
When it try's to read disk player it stops! does not recognize external drive
When it try's to read desk player it stops! does not recognize external drive
Dvd player not recognized
CLEAN THE DVD-PLAYER WITH COMPRESSED AIR.
CHECK THE ELECTRICAL CABEL AND THE DATA WIRE.
When I plunged in FANTOM firewire and USB external HD (I only use the USB) at windows start it said it wanted to (blue screen) check drive for errors. I agreed and it stopped half way at 41% and did not go...
It is entirely possible that your external hard drive is failing. I would recommend downloading Seatools for Windows (link below) and run extended hard drive test on it. Chances are if it is failing, it still recognizes within the system, but it is not readable enough for windows to display it and allow you to browse.
http://www.seagate.com/www/en-us/support/downloads/seatools
I've been using a WD My Book 500GB External for about 4 months now. It recently has stopped being detected by my computer. Short cuts to files on the drive now display the error message "The drive or...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
1helpful
My External Hard Disk - Passport 25 GB is not recognized in the system. On attaching it to the USB Port there is light glowing in the hard disk and also the arrow symbol appears in the system tray in...
4helpful
Seagate FreeAgent, 500 GB p/n 9nk2al-510 stopped working
There's not much troubelshooting you can do with a failed external disk. power off PC and hd and then disconnect all cables, wait 30 secs, power the PC on, let it boot to the OS, power the hard drive on and then connect. If the drive shows up but you still cannot access it or get weird property readings, it generally means the hd controller has failed. If the data's worth more than $1000, you can take it to a data recovery group like Ontrak or Cherry Systems, but otherwise, just get a new hd and restore whatever backups you have.
Disk drive does not recognize or read a disk
you could try removing the drivers from your device manager by going through contol panel or by right-clicking on My Computer and then on the hardware tab. you would find it under cd/dvd rom drives.Just right click and click on uninstall. Then if you dont have your driver disk you might be able to download it from softpedia.com. If you have installed drivers more than once you might be able to roll-back drivers but the best bet would be to just uninstall and re-install the drivers.
Hope this helps
Anarkist
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
2helpful
No external drive icon on desk top
This happened to me as well - i have been reading that it could be the power supply adaptor. If you can try another one - it might solve the problem. The adaptors seem to either be faulty or made to stop working. Great news for us the consumer!!
My computer stopped reading my external hard drive
Try the drive in a different USB port. If it still fails try another computer. If it still fails then it's possible the drive is bad. If the warranty has expired you may be able to find a tech savvy friend to remove the actual drive from the case and hook it up to another computer directly. If it recognizes fine then the case is bad. If it does not recognize the drive then the drive is dead.
You won't be able to retrieve the files on the drive unfortunately unless you use an extremely expensive service. These tend to run in the hundreds of dollars.
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
Top Cavs Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Cavs Televison and Video Expert? Answer questions, earn points and help others
