20 Most Recent Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive Questions & Answers
Okay the problem could be either with your computer or the external drive the first thing you need to do is try the external drive on another computer a friend's or someone's and see if it shows the files if it does not show the files on an another computer as well as your current computer then I suspect the problem is with the drive this is common especially if these drives have dropped or taking a file or gotten old if the drive is clicking and not spinning that's a big problem if the drive is spinning and you can hear it spin but it's not showing up on the computer there may be a different issue you may need to look towards data recovery for that external drive that's the best I can tell you at this time and based on the information you've given best of luck
Seagate Free... | Answered on Jan 24, 2018
The usb port probably needs to be re-attached to the board, it would likely with have to be soldered.
You may also be able to remove the actual drive from the external enclosure, look online for info on that.
Seagate Free... | Answered on Jan 12, 2018
Check your pc is directed to the correct hdd address in the BIOS.
Seagate Free... | Answered on Nov 24, 2017
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Seagate Free... | Answered on Sep 25, 2017
I'm not familiar with Carbonite but can't see why you couldn't use it to backup your new drive provided your PC just sees out as an ordinary (if external) drive. As for USB compatibility, the USB specification is backward compatable so your drive should work fine, if slower, when connected to a USB 1.0 port.
Hope that helps.
Seagate Free... | Answered on Aug 13, 2017
Check the HDD on a different USB port. It there is still problem, try that with a different computer. If it still shows this issue, try changing the USB cable. If the issue persist, its your HDD.
Seagate Free... | Answered on Jun 06, 2017
I believe a 12VDC at 2 amps would work but contact Segate to be sure.
Seagate Free... | Answered on Jan 07, 2017
Here's one case. They're not terribly scarce, but not found just everywhere, either.
http://www.amazon.com/Aluminum-External-Drive-Enclosure-Silver/dp/B000F3WB0Y
Seagate Free... | Answered on Jul 07, 2011
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
Seagate Free... | Answered on Jun 22, 2011
search in ebay website...
thank you...
Seagate Free... | Answered on Feb 01, 2011
The software that you are trying to install has not been verified for use with Windows 7.
It was verified for use with XP and 32-bit-Vista.
Look on SeaGate's web-site for an updated version of the software that will be compatible with Windows 7.
Seagate Free... | Answered on Nov 18, 2010
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Seagate Free... | Answered on Sep 27, 2010
huneybunnyra
The links below will help you assign a drive let to the drive.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Seagate Free... | Answered on Aug 18, 2010
Restore ur hardware & software configuration will fix ur problem and u might b use reginout to fix ur problem
Seagate Free... | Answered on Jul 26, 2010
Your PC is trying to boot from your external hard/flash drive.
You have to change the boot order in the bios. While booting what the screen, you'll see a message "Select F2 for boot or DEL/F10 for setup"
Go for the setup option, this will take you into the bios. Read the instructions carefully, you need to change to boot order, choose CD for 1, HDD0 for 2 anything you like for third. Press F10 to save and exit. Your
PC should now boot properly.
Or, as its just a flash drive, don't plug it in until your PC has booted.
Seagate Free... | Answered on Jul 24, 2010
First check the bios setting and see which device is your default booting.
Seagate Free... | Answered on May 18, 2010
Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive Logo
56 questions posted
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
boot device not detect
  • Computers & Internet
