How can i stop the daily reports of faxes from my bizhub c550
Try this
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: fax transmission reports
From mfc mode 1,7,1 (xmit report)or from fax 7,1 is right but then you need to arrow across from off to on or on+image to enable report printing not just on error, then set
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
SOURCE: Konica Minolta Bizhub 350, for faxing on Windows Vista PC
Yes you need the Driver.
http://help.bt.konicaminolta.ca
You can find all the drivers and help you need there.
SOURCE: konika minolta bizhub 350 fax no answer
Try altering the maximum nuber of rings until it relays the no answer message.
I am not sure exactly where that is.
ALso, you could try turing on the phone line volume so you can listen to what is heppening.
SOURCE: BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
