20 Most Recent Konica Minolta Bizhub C224 Color Copier Printer Scanner Questions & Answers
C224 exit jams
does this machine have a finisher? exit jams where after fuser? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2018 3:44:37 PM • Konica Minolta... • Answered on Mar 11, 2018
I have a new bizhub C224 when I print color is OK but when I copy color there is magenta lines or cyan lines and only in copy and the demo page is ok too
Problem with the scanner (Thing that move as it scans has the bright light and mirrors on it. Or the CCD that is the black device under the big glass on the right, get a tech out to clean and or replace Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2016 3:09:47 PM • Konica Minolta... • Answered on Jul 04, 2016
Four green lights lit up on front
where on the c224 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/23/2016 4:32:39 AM • Konica Minolta... • Answered on Jan 23, 2016
2answers
Cyan colour changes in konika minolta c224 when using postscript driver from corel draw
Download one PCL driver foe Corel.
11/18/2015 12:46:32 AM • Konica Minolta... • Answered on Nov 18, 2015
How do I get into service mode on a BHC364E?
MENU counter diplay keypad stop 00 stop 01 and need a pasword 12345678 12345678
9/3/2015 9:26:17 AM • Konica Minolta... • Answered on Sep 03, 2015
I am scanning multiple pages at once however I want them to all save as separate pages onto my computer. how do I set this up? It doesn't seem to be working for me.
when you feed multiple pages i guess you are hitting the star button in order to save them as separate pages you will need to select finish key not the start key this finish key is added with firmware if it is not on your copier already you may need to have a technician do this for you. good luck hope this helps.
2/20/2014 4:56:07 AM • Konica Minolta... • Answered on Feb 20, 2014
Trouble code c5351
c5351 tel me what is the problem
1/3/2014 4:48:14 AM • Konica Minolta... • Answered on Jan 03, 2014
How to solve konica minilta c224 machine c2558 error
SHAKE THE BLACK IU VERY WELL Clean Imaging Unit Contacts RUN GRADATION UPDATE FIRMWARE REPLACE BLACK IU
8/30/2013 3:04:19 AM • Konica Minolta... • Answered on Aug 30, 2013
No specified folder error
when setting up scanning to smb check the file path you are sending the document to. it is easier to store the folder on the c:\ drive under scans. Also ensure you have the correct username and password for the pc that has the file stored on it and set the NTLM setting to accept v1/v2.
4/8/2013 1:33:48 PM • Konica Minolta... • Answered on Apr 08, 2013
Konica Minolta bizhub 224 network connection
u have to configure network settings of machine and then try
2/13/2013 5:23:08 PM • Konica Minolta... • Answered on Feb 13, 2013
How do I cancel the transmission result report from printing
touch utility/counter button administrator settings enter password 1234567812345678touch system touch faxtouch report settingsthen change it to print error only
2/6/2013 4:51:40 AM • Konica Minolta... • Answered on Feb 06, 2013
0answers
0answers
2answers
What is the p5, p9, p16 & L-4 error code mean in konica C754 ?
Replace the Black drum and developer unit (P9) (P16) and clean the IDC forward sensor(P5) (Requires removing the Transfer belt) L4 Black Drum Rotation well passed its life.
4/22/2024 1:19:49 PM • Konica Minolta... • Answered Yesterday
O que posso fazer para remover o erro de codigo C-D252 na Konica Minolta C364 bizhub
English only on Fixya please. We are a North American website.
Error Code Pls help - Konica Minolta
Copytechnet https://www.copytechnet.com > ... > Konica Minolta Jun 20, 2012 - CD252 (C-D252) code at start up. Solution CAUSE: The Controller 1 setting is enabled in Tech. Rep. Mode without the IC-409 (Fiery® ... fuser error code C252 May 7, 2014 Bizhub C451 bad print quality, no accurate color Jun 4, 2014 Error Code Bizhub 283 with C-D272 Mar 17, 2016 error code C- D251 bizhub C451 May 19, 2009 More results from www.copytechnet.com
Konica-Minolta bizhub C452 - Error Code
Printcopy.info https://printcopy.info > model=bizhub+C452 Code: CD252; Description: No relay circuit boards for IC-412 mounting at IC-412 mount setting; Causes: MFP board (MFPB) Relay circuit boards (VI-505) . ..
3/3/2024 9:54:07 PM • Konica Minolta... • Answered on Mar 03, 2024
2answers
Konica Minolta Bizhub C454. How to download firmware please?
C454 and C454e firmware - Page 2
Copytechnet https://www.copytechnet.com > ... > Konica Minolta May 4, 2019 - Re: C454 and C454e firmware. Hi there, I hava Konica Minolta Bizhub C454 with ROM Version: b-IZHUB-c454 - imgbb.com C454 and C454e firmware May 5, 2019 UPDATE FIRMWARE ON c454 Jun 19, 2015 Bizhub latest firmware? Mar 10, 2022 Firmware question Jun 19, 2019 More results from www.copytechnet.com
Updating the Firmware of This Machine
Konica Minolta Manuals https://manuals.konicaminolta.eu > contents User's Guide. bizhub C554 C454 C364 C284 C224 ... A firmware for this machine can be downloaded from the Internet to update the machine firmware.
Download Center - KONICA MINOLTA
konicaminolta.ge https://www.konicaminolta.ge > download-centre The download center of Konica Minolta! Find everything from driver to manuals of all of our bizhub or accurio products.
2/16/2024 1:29:36 PM • Konica Minolta... • Answered on Feb 16, 2024
Konica Minolta Bizhub C224 Color Copier Printer Scanner Logo
22 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
cyan colour changes in konika minolta
  • Office Equipment & Supplies
