Clear the print que. Sounds like you have a print job in the que that has a European paper size. Example A4. U.S.A. useS 8.5x11 or letter or letter (r)
Hi Press and HOLD the Start/Pause and Cancel buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance. Daniel
All
error codes start with the letter "E". An error code of E11 will have
the five indicator lights flash once and the Start indicator light
flash once.
Some
models of Frigidaire washers come with a digital readout display that
informs the operator of the unit's function and any errors.
Error codes
indicate that a problem has occurred and should be addressed. Different
models of Frigidaire washers may vary in their fault displays.
Some
washer models use flashing lights at the unit's start, door lock, wash,
rinse, final spin and control indicators to display error codes.
If
the five indica
tor lights flash more than nine times, this signals a
letter in the error code. The letter "A" stands for 10 flashes, "B" for
11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error
code of EB2 will have the five indicator lights flash or blink 11
times, and the Start indicator light blink twice
na na na look for a plug under dash black ussually very small letters a and b are probably the only ones beside each other with metal inside the plug holes needs a cotter pin in between to make your dash indicater to blink count the blinks all codes have 2 numbers eg 11 or 14 or 44 blinks will be seprated by spaces that light only comes on when bad **** happened in the computers world
It sounds like some other device might have taken the drive letter that we assigned to your external hard drive. The links below will show you how to change the drive letter.
Let me know if you have any more problems or questions
Probably you are printing for a legal size paper on letter paper. Check the paper size and be sure you have letter 8 1/2 X 11, or whatever real paper you are loading on the printer.
Un-hook it from the computer. Turn it off then on. See if it may be a code from the computer causing it.
Also, Check inside and make sure there isn't anything that is keeping the carriage from moving freely .
Also, Have you changed cartridges lately?
Reseat the cartridges.
