20 Most Recent Sony Bravia XBR-Series KDL-46XBR4 46-Inch 1080p LCD HDTV Questions & Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Sony Bravia... | Answered on Oct 11, 2016
What your describing sounds very much like a video board issue some part is not working properly until it warms up. Eventually it will most likely need to be replaced, If you are not sure what board or part is bad, in the long run it might be a better idea to just replace the TV.
Sony Bravia... | Answered on Oct 10, 2016
Sony Bravia... | Answered on Oct 02, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sony Bravia... | Answered on Apr 28, 2016
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Sony Bravia... | Answered on May 08, 2015
I'm a 100% certain your LCD panel is bad, I've run across a lot of Sony/Samsung's with the same problem. It can be fixed but involves taking the TV apart. I have 5 flat screens in my home, 3 of them had the same problem yours had, I patched them and they are working fine! A replacement panel will cost more than a new TV set so that's not an option. If you do no wish to fix, I would suggest putting it on Craigslist as a parts unit, someone will buy it. If I have been a help to you please sign my guest book
Sony Bravia... | Answered on Jun 10, 2014
Power supply regulator board problem. Contact any service technician. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Sony Bravia... | Answered on Apr 16, 2014
you need to replace defective capacitors in the power supply of the tv
Sony Bravia... | Answered on Aug 06, 2013
In most cases, the issue might be with the Java contents on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
You can enter the model # of your Blu-ray Player to download the firmware update for your player.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
Sony Televison &... | Answered 12 hours ago
you need to change input source to air or antenna
Sony Televison &... | Answered 2 days ago
An out-of-focus picture is usually caused by poor regulation of the Hi-Voltage circuits. In these older Sonys' it can mean poor solder joints in the horizontal output stages. Check all solder joints on the flyback transformer and filter capacitors on the secondary low voltage side. A less common problem would be a short in the picture tube or arcing in the focus block. Any of these problems will require the services of a competent service technician. This old of a set should not be considered for repair, but replaced with a newer flat screen.
Sony Televison &... | Answered on Nov 05, 2019
Sony Bravia XBR-Series KDL-46XBR4 46-Inch 1080p LCD HDTV Logo
Popular Tags
12 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
when tv offovernight turned right side
  • Televison & Video
