HARD TO START. WILL ONLY RUN ABOUT 20 SECONDS. Ocassionally if it starts. If for any reason it stops or you stop it it will not restart. On a few rare occassions I have pulled the spark plug and cleaned it and it will restart and run for a while. Then the same problem. This unit has always been very difficult since it was purchased.
Your carburetor needs cleaned. Disassemble and spray with carb. cleaner. TIP: Use a Den Tek Brush, (used for cleaning between teeth),to clean small portals in carb. check the small screen in carb. for debris. Reassemble and start. If it still doesn't run properly, buy a carb. kit and replace the small screen, needle valve, gasket(s), and diaphram. this should definitely do it.
Jim
Did this solve the problem?
Hear is the link to the Den Tek Brush: (http://www.amazon.com/dp/B00133OCWU/ref=...)
Jim
