Frigidaire GLGH1642DS Front Load Stacked Washer / Dryer Logo
Posted on Jun 04, 2009
How do you acsess the belt to check tension on frigidaire front load stacked washer dryer
cjcjc
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Apr 03, 2010
cjcjc
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
319
Points
Remove the lower panel on the back side .
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
I need a diagram on how to open up the back or front to install the dryer drum belt for my Frigidaire FLSE60RGS0. we bought the belt, and I did get a diagram on how to install belt, but doesn't show us...
Disconnect the water, vent duct, and electric connection to gain access to the rear of the machine. Be prepared to catch any water that comes out of the hoses.
On the rear of the dryer, remove the panel that's behind the dryer section (upper panel).
If the belt is intact, make a drawing of the belt's route.
If the belt is broken, remove and discard it.
Slide the new belt onto the drum to approximately where it belongs (lined up with the motor pulley). I think this model might have a groove for the belt where it rides on the drum.
With the slack portion of the belt, squeeze it to make a loop and push it through and onto the tensioner pulley on the bottom of the dryer.
Using the tensioner spring to relax the belt (pull it toward the motor pulley), slip the belt onto the motor pulley.
Check the belt by pulling on it to see if the drum, motor and tensioner are rotating freely (don't pinch your fingers!).
I am not the best at abstract description. I hope this helped.
Good luck from Detroit, MI.
The dryer squeaks loudly
The dryer has been over loaded too often. Try to determine if squeak is from the front or back. The felt pad dirty. If it is from the bottom, then the tension roller is binding and needs lubrication.
I am trying to find the right dryer belt for FEX831FS1
available through sears but the part number is
134503900
16.00 dollars
2helpful
How do I replace the washer belt
Remove the front panel to the washer. Screws across the bottom. Push down on the front panel, then pull it out. Belt should go around transmission, motor pulley and tension roller.
2answers
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
