ASUS EA-N66 Dual-Band Wireless-N900 Gigabit Ethernet Adapter Logo
m
mq6364 Posted on Jan 28, 2014
Setup wizard can't get the setup page to appear when i connect
jihadjared
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Apr 25, 2014
jihadjared
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
7008
Points
23
Try doing a hard-reset on the unit. There should be a little inset button on the rear of the unit where you can press it with a pen or paperclip. With the power supplied to the unit, press and hold this button for 10 - 15 seconds until you see the indication/status lights change their pattern. Sometimes all of them will become solid lit, sometimes they will flash, just keep your eye out and look for it. If you dont notice anything, then just make sure you give the button a solid 15 second hold. It can't hurt.
After you do this, try logging into the configuration page and resume setup. Sometimes routers crash. Most all of them are built on the Linux operating system and a crash or glitch is bound to eventually happen. A proper reset usually fixes things like frozen ports, broken wifi or other problems that just seem to appear for whatever reason.
Asus tablet Zenpad10: after factory reset Setup Wizard is crashing
Try holding the power button and the volume up button same time when hear a vibrate realise them both
The router installs fine on one lap but I still can't connect my other laptop
your first option is to go to http://192.168.0.1 Here Select admin from the drop down menu and leave the password field Blank.
Once the page loads youll see a series of options. this is the routers linux interface section. you will see D-link on the top left.
Select the first option Install router.
the steps would be as follows.
Step 1.
Insert the Router Setup Wizard CD in the CD-ROM drive. follow The step by step instructions. Once you done this And i believe you have already. see step 2
Step 2.
Select the Option
Setup on the Top > Internet is on the left side.
Under the Internet connection Wizard Hit the Setup Wizard button.
Step 3.
Now on the Setup page Same place where the setup Wizaed is. just below their is another option called Wireless Security Setup Wizard.
Press the Launch Wireless Security Setup Wizard Button.
Read the 3 steps then click the next button to continue.
Steps for step 3.
1. Enter a SSid this will be the network name you see when you want to connect to your own network. example.. MyHome
2. Select your security option then click next. (For simplicity chose WEP)
3. click apply.and let the router reboot.
when it comes back online you should see your network you just setup. our example was MyHome.
If you are new to router setup. use the Wep security called Good on your routers security WEP. and just write the key it gives you down. this is the code you need to connect your devices and is considered ok for a simple home network.
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
When i try to connect it will not get connection to internet. If i by pass the router it will connect
Hi rarebed, Your router needs to be set up D-link has an automatic setup wizard just connect you router to the computer and type 192.168.1 in the internet's address bar. hit enter and enter again on the next page (you don't need a password) then pick automatic setup and follow the wizard. http://www.fixya.com/support/r4219065-set_up_wireless_router_use_wireless For General manual instructions
Where would I find my network security key code?
this is created during the setup of the router.
Log into the router with either 192.168.0.1 or 192.168.1.1 via the web browser and the login page will appear and enter "admin" then "password"2. user the wizard to set up your key and password for the connection.
check the user manual of your particular unit.
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
Need set up Lexmark C534n to our office network.
Does the printer have an IP already assigned to it?
Print out a network settings page:
Printing a network setup page
If the printer is attached to a network, print a network setup page to verify the network connection. This page also
provides important information that aids network printing configuration.
1 Make sure the printer is on and Ready appears.
2 From the control panel, press .
3 Press until Reports appears, and then press .
4 Press until Network Setup Page appears, and then press .
After the network setup page prints, Ready appears.
Note: If an optional internal print server is installed, Print Network <x> Setup Page appears.
5 Check the first section on the network setup page, and confirm that Status is “Connected.”
If Status is “Not Connected,” the LAN drop may not be active, or the network cable may be malfunctioning.
If that is an IP not on your network, then you need to change that IP to an unassigned IP that is on your network.
You can do that by typing in the IP of the printer into a web browser (example: Http://ipaddress)
Then you should be able to modify the IP address from here.
Once the printer is on your network, make sure you have drivers for it installed and then just map any worksttaion to it.
1helpful
2answers
I need help on how to use setup wizard
hat type of connection do you have? if you connect everything and put 192.168.0.1 in the address field in the browser you will be taken to the dlink router setup page. the default username is admin and the password is admin. from there you should see a setup link.
I need Lexmark X1130 Installation CD for printer setting not the drive CD
Here is driver download page for X1130, just click here, select printer model, and download.
This is the setup procedure.
  1. Unplug printer USB from computer.
  2. Chose OS version and download the driver.
  3. After downloading run installer file, this will start printer setup wizard.
  4. Connect printer back when required from setup wizard.
Don't forget to rate the solution appropriately.
Many thanks.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
