My paper loader wont accept paper that is to say paper is no log
What I understand the paper tray is installed correctly.
Some machines have push sensors inside the at the end of the tray. Look inside the area where the tray goes in with a flashlight. Everything is mostly black so it is hard to see.
Look for actuators that need to be pressed. Locate the tray end area to see if there is a plunger that pushes in the switch actuator. Sometimes the plunger is missing on the tray, or the slide selector on the tray is not positioned correctly. I cannot see this tray so look for these common areas.
Sometimes you can gently move actuators up and down, and phsyicaly see if they fell out of postion or just completely broken.
Also, paper dust is common in these areas. If the sensor is dusty, the sensors will tell the machine there is a jam, if you can clean the sensors from debris even excessive tonor or developer that falls in these places a lot.
Good luck.
