20 Most Recent Life Fitness 9000 Next Generation Treadmill Questions & Answers
1) Flip the treadmill on its side to expose the bottom 2) remove the two screws holding the rectangular metal wax cover 3) remove the wax cover 4) you should see a bag of wax, replace it with new 5) type in 5-1-2-5-Enter to reset the wax statistics
Life Fitness... | Answered on Sep 19, 2018
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Life Fitness... | Answered on Feb 25, 2014
Could be a number of reasons - where is the black dust coming from? remove the motor hood and check for misalignment of the drive belt from motor to the front roller.
Life Fitness... | Answered on Jan 16, 2013
unplug machine, tip over carefully and look under machine for a disk like part with a electronic eye. is eather loose,missing or the eye needs cleaning,adjustment or replacement.
Life Fitness... | Answered on Dec 04, 2011
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Life Fitness... | Answered on Jul 20, 2010
Send an e-mail to info@fitnessgt.com to request the Life Fitness 9000 manual for free.
Life Fitness... | Answered on Feb 20, 2010
you must replace the motor or send it to repair, they must re-winding back
Life Fitness... | Answered on Feb 05, 2010
Ther are two adjustments to check,the tightness of the walking belt(the screws at the back of the treadmill) and the tightness of the motor drive belt under the motor cover.
Life Fitness... | Answered on Aug 15, 2009
Look for a motor reset button along the bottom edge of the unit.
Life Fitness... | Answered on Aug 10, 2009
http://us.home.lifefitness.com/content.cfm/ownersmanual
You can possibly find your model here for owners manual.
Life Fitness... | Answered on Jul 11, 2009
Life Fitness 9000 Next Generation Treadmill  Logo
Popular Tags
16 questions posted
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Android Man
Android Man
Kenneth Simmons
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Life Fitness Exercise & Fitness
Most Popular Question
lifefitness tr 9000 treadmill 1997 model
  • Exercise & Fitness
