Please record the amount of time that it takes until your device goes into sleep mode and set a timer for 5 minutes less than that time everytime you begin to use the lg device. At the points the timer/alarm goes off, you can simply lower/increase the volume and the lg's internal sleep timer should be reset.
Is it ''sleep'' mode or ''Hibernate'' mode? If ''Hibernate'', then that is the problem. Turn off ''hibernate.'' If it is in fact just ''sleep'' mode, check to see if it is set for ''enter password to exit sleep'' _and_ you don't have a password set up... then either create a password or set it so that it does not require a password upon exiting sleep. Also, you can always resort to resetting everything to ''default'' settings. (This will not effect any data on the phone, and you can take your time setting all the settings ''just right'').
* check com cable all thru the video card socket,also check you video graphic card pci if its inserted properly,try to clean it first.
* might your pc is in Hibernate or Sleep mode
A power management mode that conserves power by powering down the system. In hibernate mode the current state of the system is saved to the hard drive, and the system will power down. When a user turns the system power back on, the saved information is read from the hard disk, restoring the last used settings. Hibernate mode is similar to sleep mode, however in sleep mode the power cannot be shut off.
go to control panel > power management and change or default the settings you wish.
I think I understand what you are describing based on some inadvertent button pushing on your part.
Sleep mode programming on the VSI controller by Penny and Giles Drive technology is the idle time of the power chair before it "goes to sleep". This computer menu is accessed using a hand held PP1 programmer that is plugged into the charging port of the joystick. Using this programmer one can scroll down to the sleep mode menu and set the time from I think 1 to 120 minutes ( I have not accessed this particular programming menu for quite some time).
If I put in 10 and save this number the chair will go into sleep mode after sitting and not being used for 10 minutes. The control may have dropped one of the settings due to a program glitch. I do not know of a way to reprogram this by pushing buttons on the control itself.
You should drive the chair into a local dealer who has a PP1 programmer and let them program it for you. This is a 2 minute deal and they should do this as a courtesy for you at no charge. If a technician comes out to your house they may charge you a minimum 1 hour labor charge.
While they have the programmer plugged in, have them check the fault log for any other problem areas. Hope this helps.
For clarification, may I know how long that your computer before it going to sleep mode?
You can change the settings on how the computer hibernate or gone to sleep mode by going to display properties >> click on the screen saver tab >> clcik on the Power button. There you can set the time on how long the computer will gone to sleep.
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode.
Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode.
Good Luck.
Leave it plugged in for about 10 minutes. The battery just needs to charge a little more. Then you can come out of sleep mode.
If it is locked in sleep mode. Just hold the power button down to shut off the computer. Let it charge, you can now reboot, and keep charging after about ten minutes.
1. File manager in ipcsuite
/System/Library/SystemConfiguration/PowerManagement.bundle
2. Find the file:
com.apple.SystemPowerProfileDefaults.plist
Then rename it to:
com.apple.SystemPowerProfileDefaults.plist2
