Belt keeps coming off- Dirt Devil Breeze Cyclonic Bagless Upright Vacuum 1 year old. Tried new brand name replacement belts, correct for vacuum, installed properly, roller bar tests out fine (spins great) still belt falls off after a minute. On the same carpet it was fine until last month. It looks to me like there is too much space between the end of the motor shaft and the plastic housing- more than other vacs. Still why is it only a problem now? Is there any solution or just toss it in the trash and buy a hoover?
SOURCE: Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
